will a 4 core rad. out of a 78....
Discussion in 'The Garage' started by NEK5, Aug 22, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    fit in my rig? was just over my buddys helpin him and his dad finish packin the U Haul and it was in his basement and told me to take it, so i did.......will it fit?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The only differences I have found is the height changes . Some are taller than others . The brackets are different for the tall or short radiator . The tall go over the core support or out the top of the engine side and hold the rad , the short go on the engine side of the core support below the core support top and hold the rad . The shrouds correspond to what you got too .
  3. dyeager535
    26,980
    Upper radiator hose changed diameter at some point, can't recall the breakdown for that. It can be worked around, but measure them beforehand to check.
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Do you need a new radiator? The one you took might be in worse shape than what you have currently. You cannot inspect a radiator from just inside the cap.. Just a thought..
    John
  5. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    I put a 4 core from my 79 into my 89. I was changin the 89's waterpump and somehow I put a hole in the radiator, so I took the radiator out of my 79, its got no engine/trans so it won't be goin anywhere, anytime soon.
    I had trouble getting the 89 shroud onto the 79 rad. But my bottom part of the shroud had a big crack in it so i just left it off.
  6. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    the radiator in my truck is fine,as is the 4 core, but i was just wondering if it would be worth the upgrade?
  7. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    After I installed the new waterpump(stock replacement), new hoses, 4 core radiator, and new thermostat. The runs like 10 or 15 degrees cooler.
  8. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    worth it?
  9. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    "If it ain't broke, don't fix it" is my opinion in this case. Keep the 4 core as a spare and put it in if you need it. I would not mess with something thats working. It just begs for a can of worms to be opened up.
    If your current radiator keeps the motor at the T-stat temp, why mess with it?..
    Just my opinion.
    John
  10. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    thanks alot man, i sure dont need another project, but if it was well worth it, i might have done it
    EDIT: worth keeping as a spare, or sell it?
  11. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    All depends on your funds situation..
  12. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    well, i could use the extra money, my radiator is fine now...whats it worth?
