Will a 6.2 power stering pump work on my 80 chevy
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84CUCV, Jul 26, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    The truck in runing ok. Just needs a new power steering pump. they look the same.
    Thanks mike
  2. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    When I mounted the 6.2 hydroboost on a 350 I had to modify the brackets. The actual pumps appear to be the same, at least the part numbers are the same according to partsamerica.com. However the reservoirs are different. The 6.2 hydroboost reservoir has a barbed fitting for the extra return line. Also the shape of the reservoir must be different, hence the necessity of modifying the brackets.
    Hope that helps.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Yea, that helped thanks
  4. cityfarmer2
    cityfarmer2 Guest
    I have an 84 CUCV and with a little creativity I was able to mount the power steering pump on a 350 SBC. Getting rid of the old desiel was the best thing I ever did.
  5. 73k10sub
    73k10sub 1/2 ton status
    Jul 23, 2001
    223
    Tulsa, OK
    I could not make the diesel pump fit my '73 small block brackets. I scored the brackets for a hydro boost pump off a small block in a P model (step van, bread truck, Little Debbie, etc.) van. One bracket still required a little relief work with the grinder to get the diesel pump to fit. LOL!
    Ronnie /forums/images/graemlins/truck.gif
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Thanks for the help guys
    mike
