Will a 6.5" backspacing rim fit a dually D60 front?
Discussion in 'The Garage' started by thatK30guy, Mar 4, 2006.
  1. thatK30guy
    Jan 12, 2001
    32,076
    55
    15x14 wheels with 6.5" bs.
    Will they fit and make the truck look like a SRW rather than a DRW?
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    It should work it is only 1/2" to 1" less BS than a Hummer rim.
    Ira
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Forgot to ask one other thing: calipers still need grinding, too? :confused:
  4. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    I thought it was only if you had a small amount of BS (like 1") that you did NOT have to grind 15" wheels to fit on a D60.? All I know is that my H1's fit fine :p
  5. sandawgk5
    Oct 28, 2003
    6,881
    With the dually front what is the stick out of the mounting flange 4-5"s. That would make the wheels fit the calipers like a 1"-2" backspaced wheel. If you have to grind at all it will be minimum nothing like my wheels with 4.25 backspacing:D .
    Ira
