will a 700r4 hold up to around 300hp
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by t's85chevyk5, Jan 30, 2004.
  1. t's85chevyk5
    t's85chevyk5 Registered Member
    Jan 29, 2004
    66
    Phoenix, AZ
    Im going to drop a vortec 350" in my 85 soon. after the mods i plan on it being around 300hp. I have a 6 month old rebuilt 700r4 with the upgrades that the later model 700r4s had. It does not have proformance upgrades. Is that going to be able to handle the motor?
    Thanks, T /forums/images/graemlins/k5.gif
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Add a shift kit and it will be handle the extra power no prob...
    A properly equipped th700 can supposedly handle 700HP from art car. /forums/images/graemlins/waytogo.gif
  3. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    The 700R4 can handle the HP, what it has a low tolerance for is heat. If you don't have an aux trans cooler, add one, that will do more for the longevity of you trans than anything else you can do.
  4. dyeager535
    26,982
    191
    From what I've seen, the "early" (pre-87 I think) CAN'T be built the same as the later ones. The auxiallary "valve body" didn't exist on the earlier ones.
    No guarantees it will fail, but I don't think I'd expect it to stand up to a lot of actual abuse. Driving style will govern how long it lives more than anything else, if it was put back together right.
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    As long as the throttle valve cable is adjusted properly and you keep the heat down it'll be alright. Don't run it in overdrive if the converter won't stay locked up.
    I have the original 700R4 in my 84K10. It came from the factory with a sizeable auxilary ATF cooler because it was a plow truck. This is probably the only reason it's still alive and kicking.
    It handled the first 62,000 miles of plowing abuse, never being serviced, being overfilled, and 2.73 gears. The next 30,000 miles have been with several different motors behind it, 33s with those 2.73s, and relatively frequent 6,000rpm shifts.
    It's approaching the 100k mark so I've been collecting parts to rebuild one. It's not a matter of if a 700R4 will fail, it's when it'll fail.
  6. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    DID I HEAR AN EHCO?????
  7. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    You can build a old tranny to newer tranny specs, their all the same pretty much but with different internals, any year can be built stronger, just older ones need a little more of the green stuff to do it.
  8. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ] yep! /forums/images/graemlins/waytogo.gif
  9. sandracer0004
    sandracer0004 1/2 ton status
    Jun 24, 2003
    108
    San Jose, CA
    how about a 454 in front of it?
    for towing?
  10. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    for towing?
    Probably not with it being stock.
    I wouldn't be afraid at all to run a big block in front of my th700.
  11. t's85chevyk5
    Jan 29, 2004
    66
    Phoenix, AZ
    I do love big blocks, but i didnt get my grimy mitts on one for free like the vortec350 /forums/images/graemlins/k5.gif
  12. dyeager535
    26,982
    191
    Pretty much the same with different internals? Isn't that the point?
    The later ones are cast differently. I thought the change was '88, but it may have been '87.
  13. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    How about adding 4.88 gears too, wouldn't that ease the stress on the 700?
  14. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ]yes
