Will a 79 Tach work on a 75?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LoggieStyle, Jul 24, 2002.
  1. LoggieStyle
    LoggieStyle Registered Member
    Jul 10, 2002
    78
    Tujunga, CA
    I bought a tach dash from a 79 chevy truck, what series of truck I'm not sure. I was wondering if someone could tell me if this will work on my 75 K5? If not is there a inexpensive way to make it work or should I just sell the dash to someone else?
    Thanks guys,
  2. doc70sub
    doc70sub 1/2 ton status
    Oct 8, 2000
    688
    Thomasville, NC
    I'm in the same boat, does anyone know? Thanks!
    doc
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    I *believe* it will bolt in directly, the only thing that may be different is the font used. If you have the dash in front of you, pull the bezel off the 75 and compare. /forums/images/icons/tongue.gif
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the wiring changed significantly in 77
    it can be made to work, I did it, I had to move the pins on the guage plug to match the newer tach cluster
  5. LoggieStyle
    Jul 10, 2002
    78
    Tujunga, CA
    Don't have it yet but I'll do that when I get it, thanks.
