Will a 81 and up Dash Pad fit a 1978 Truck?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rocko, May 11, 2002.
  1. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    The dash's look the same.. the only difference I see is the curve of the old style dashpad ..
    Has anyone updated their interior?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    When I was back in body shop school, there was a guy who had a '78 (I think) and he swapped in a new interior and front clip from an '85-ish truck.
    I remember asking him about the dash and he said they bolted right up in place of the other. No mods whatsoever. /forums/images/icons/wink.gif
  3. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Thanks Wes... I find more "in good condition" dash pads out of newer model vehicles.. and I'd like to put one in my 78 K-30.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Yes it will bolt up just fine. Another difference is that the newer dash pad also hangs farther over the gauge cluster area making it easier to see in high light conditions such as sun beating through driver side window.
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You will have to make one change. The newer pads are more shelf-like on the passenger side and there is more of a ridge between there and the instrument side. When you go to try to put it on, It may not sit flush in the center. Take a hammer and beat down the support in the center and it will go right on. You will also need to change out the instrument bezel. I think the newer ones are thicker at the top and the older ones will not work out right. Good luck.
  6. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Must use 81 to 83 dash bezel...last year for the wiper switch to be mounted in the dash...also the dash pad clips are different...the far drivers side clip cannot be used and the new pad will cover a portion of your vin tag (78 up). Looks good when you do the door panels also!
    Azblazer
  7. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    MAN ROCKO LIKE WE HAVE ENOUGH STUFF TO DO ALREADY.
  8. 74k5inVA
    74k5inVA 1/2 ton status
    Dec 13, 2001
    329
    Virginia Beach, VA
    do you know if this will also work for a 74, can i take the dash out of an 88-91(not just a pad but the whole thing) and put in a 74? no major problems?
