will a burb tranny fit
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Aug 10, 2002.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    My dad has an 85 suburban with a 350 in it and I have an 85 Jimmy with a 305 there both automatics. WOuld I be able to take his tranny and put it in my truck his was rebuilt about 6 years ago but hasnt been driven more than 3,000 miles. Would this swap work what would I need to change or would I need to change anything???
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    is the burb 2 or 4 wheel drive?
  3. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    Its a 4x4 also.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if they are the same ie t350 or 400 or 700r4 then it will bolt right in if you have a t350 and the burb is say a 700r4 you might need to move the crossmember (no biggy) and would need to have your front driveline lenthend and the rear shortend
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    About the only thing different in the drivetrain between a 1/2-ton Sub and a K5 is the length of the rear driveshaft. /forums/images/icons/cool.gif If the Sub is a 3/4-ton, then it probably has a Turbo 400, so you would need to move the Sub transfer case to your truck as well.
  6. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Hope your dad knows that you're taking his tranny!!!!LOL
