Will a cat work AFTER a muffler? (Emissions?)
Discussion in 'The Garage' started by y5mgisi, Feb 6, 2004.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    1.I have been running without a cat now for a while /forums/images/graemlins/ignore.gif, and now my tags are up. I need to get one in there, But it would be a pain to put one in in front of my muffler. However it would be easy to put one in there after the muffler (about 3'-3 1/2' away from the colecter) Would this stil work to pass emissions test? Or will it not get hot enough to make it work properly.
    2. Also anyone know any tricks to help it pass the sniffer/dyno test? (1990 3/4 ton sub with 350TBI 200,000 origanal miles.) /forums/images/graemlins/ears.gif
    3. Anyone got a good cat layin around?
  2. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Needs to be as close to the manifolds unrestricted as possible for correct light off.
  3. 89BlazerK5
    89BlazerK5 1/2 ton status
    Aug 24, 2002
    134
    i had to put 2 cats in mine. just passed the other day. i would put them in in front of the muff. go on ebay and go to the ebay store "performancepeddler" he sells magnaflow high-flow cats for $31.50 best price anywhere. i bought 2 from him.
  4. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Good deal thanks for the tips /forums/images/graemlins/peace.gif
  5. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I agree with you on this point, but as a counterpoint... When I had my 93 Chevy with a 454, it had the cat after the muffler. This was the stock setup, I am sure. Maybe because it was a big block that it was done this way. Exhaust gets hotter maybe?
    And to the original poster, PM Mudfrog, he sells all kind of exhaust products at extremly good prices.
    John
  6. the cowboy
    the cowboy Registered Member
    Feb 5, 2004
    15
    Las Cruces, NM
    Man, it must stink to live in Oregon. I have an 89 3/4 ton Sub, 350 TBI, and run dual flowmaster 60's here. Gettin' rid of that cat really made a difference /forums/images/graemlins/grin.gif
    Those converters need to get hot to work. put it in front /forums/images/graemlins/thumb.gif
  7. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Free, come by and pick it up:
    /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/waytogo.gif
  9. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    California has some weird laws.
    Technically, your suppose to replace the Cat with a Factory equiv and it must be in the Stock, factory location.
  10. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    The cat needs to heat up to work, therefore its got to be closer to the engine. To help pass emissions test, lean out your truck if possible but dont missfire or that leaves unburned gas. I think Gasohol (10% ether in the gas) will help a little too.
  11. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    My 93 K3500 w/a 454 has the cat after the muffler, too. Stock set up. Probably won't be there much longer. /forums/images/graemlins/grin.gif Not sure why they did it that way. I had always heard that they needed heat to start working.
  12. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    [/ QUOTE ]]
    not if you register your truck in a DEQ exempt area. /forums/images/graemlins/waytogo.gif
  13. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I wouldnt use a used cat. If you want to pass, put a new cat on, itll pass, that is if your not horribly polluting. That was always the joke in smog class, if the car filed, heck just throw a cat on it, itll pass!
    Oh and FYI if you have nobbie tires, dont waste your time goin to get smogged, theyll just tell ya to go put some differrent tires on. /forums/images/graemlins/thumb.gif
  14. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    How come yall dont just have some cheap exuast made up with a couple cats and some cheapo muffler and as little tubbing as possible just to put on when you go have it inspected?
  15. dyeager535
    26,980
    'Cause new cats are almost a non-issue when it comes to restriction. Get a high flowing replacement cat, and you won't notice it's even there.
  16. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Now theres an idea. Two cats?!? would that work? would that be like twice the emissions fixing or would that not work.? /forums/images/graemlins/thinking.gif
  17. dyeager535
    26,980
    Yes it can work, but this is the reason you can't add or remove the number of catalytic converters originally on a vehicle...as previously mentioned, cats need to be at a certain exhaust temperature for correct operation. Not sure how narrow that operating range is, but I know it's critical.
    Too close or too far, you change the amount of heat it sees, and how are you going to measure that like GM did?
    On top of that, you are reducing by HALF the amount of exhaust passing through the converter, which means that the heat typically carried from the other bank, would no longer be present.
    I'm not saying you couldn't just slap a couple of them on there and have it put out great sniffer numbers, just that like in head porting, if you do it wrong, you can make things worse. And even if it IS better than original, how do you know placement/operation is optimal, besides lengthy testing?
  18. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Just get one high flow cat and be done with it. Any good exhaust shop worth a thing can cut out the pipe and slap one in there for a good price and make it look good.
