Will a D70 from a '78 Dodge pickup work on my K5
Discussion in 'The Garage' started by mofugly13, Sep 28, 2003.
  1. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Will a D70 from a \'78 Dodge pickup work on my K5
    At the junkyard yesterday I saw a Dodge utility bed pickup wit ha SRW D70 in it. I donno what gears it has, or the spline count but I thought I'd come to CK5 and ask if I should be going back to take another look at it /forums/images/graemlins/confused.gif
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: Will a D70 from a \'78 Dodge pickup work on my K5
    Large 6 lug pattern or standard 8 lug?
  3. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    8 lug
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Anything can be made to fit our trucks. I would make sure the WMS to WMS is the same or close to what the GM axles are. 67" up to 69" is ideal so it doesnt get wider than the front axle. /forums/images/graemlins/thinking.gif
    Other than the measurements, just a matter of locating the shock mounts and spring perches to fit your rig. /forums/images/graemlins/thumb.gif
  5. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Since it is from a late seventy's Dodge axle it more than likely will be a 1-1/2" 35 spline "B" series Dana 70 . It should make a nice choice as far as gear and parts availability .
    Get the B.O.M. number and post it - I am sure several folks here will be able to tell Ya what it came with originally .
    Tom
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Closed knuckle or open knuckle? I thought all 70 fronts were closed knuckle.
  7. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    It's a rear axle.
  8. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    I have one from a dodge and about that same vintage in the rear of my Blazer. You'll have to move the spring perches and shock mounts other than that I love it. I'm running 5.86's with it welded and disc brakes. Have never had a problem with it. But be sure to run the numbers so you know what it is and what parts you need to buy for it. As an example dana 70's have different gear offsets... ask me how I know. /forums/images/graemlins/thumb.gif
