will a dodge 60 work?
Discussion in 'The Garage' started by rpm35, Dec 29, 2003.
  1. rpm35
    rpm35 Registered Member
    Jan 14, 2003
    71
    Billings, MT
    I can get a D60 out of a 80's dodge for $600. It is in great shape I just need to know if it bolts up to my 91 jimmy. Are there any pros/cons to running a dodge 60 over a chevy 60? Thanks for the help.
  2. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    When I searched this issue recently I found the dodge front axle is narrower but works other than that. No personal experience though.
  3. rpm35
    Jan 14, 2003
    71
    Billings, MT
    Does anyone know how much narrower?
  4. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    it's like a half inch. you can either bend the leaves in, or get a set of offset bushings. I'd do the bushings, personally.
  5. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    The spring pads are half inch closer together, not a biggie. But the axle is 2 inches narrower than a chev axle. You can run a lit less back spacing or use wheel spacers and youll be OK.
  6. rpm35
    Jan 14, 2003
    71
    Billings, MT
    Thanks for the info /forums/images/graemlins/thumb.gif
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have a dodge dana 60 in my blazer for 2 years now all i did was spread the springs a little to bolt it in. i also needed a chevy steering arm and a chevy yoke other than that it bolted right in and have had 0 problems with it /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  8. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    Front 60? I run a dodge front 60 and the only thing I wish I had different was chevy outers on the hubs. I run Selectro
    lockouts,, due to the hubs not having splines and only studs on the hubs. I also know that if you upgrade to 35 spline axles Selectro does not make lockouts.
