Will a Dodge d60 with CAD work on SAS?
Discussion in 'The Garage' started by K5MONSTERCHEV, Jan 31, 2004.
  1. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    So Im gonna do a SAS on an '01 HD. The guy got Dana 60 out of a '01 Dodge, one with CAD. Will the axle work, as long as theres vaccuum to the disconnect? All help would be appreciated here! /forums/images/graemlins/1zhelp.gif
  2. nvrenuf
    Jan 7, 2002
    13,074
    245
    Mobile, Al.
    I would assume that you're correct about the vaccuum.
    FYI - those axles are notorious for hub bearing failure with bigger than stock tires.
  3. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Hub bearing failure eh, ill keep that in mind.
  4. gmule
    gmule 1/2 ton status
    Apr 2, 2002
    196
    Conifer Colorado
    They also use ball joints instead of king pins
  5. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah, i know. The guy already has the axle. I heard something of cable to actuate it?
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Yeah I mentioned it in your other thread, I know there is a cable actuation unit out there. JC Whitney sells it likely
  7. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yes someone told me he thought JC Whitney sold it also, Ill give em a call!
  8. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    PosiLok has the cable device for Dodges, too. They make the ones for GM IFS trucks.
  9. bluejeep
    bluejeep 1/2 ton status
    Jan 9, 2004
    106
    Des Moines, IA
    IIRC, those use all 30 spline inners. By the time you upgraded that, then upgraded the carrier/locker, then upgraded to add manual hubs, you will far exceed the cost of a ford dana 60. But, it's up to you. Maybe you don't really need all the upgraded parts and this would be a low buck upgrade as compared to the IFS.
  10. rodzzilla
    953
    Grinnell, IA
    Might be able to do a little bit at a time as the money will allow. Like you said, even w/the std parts, still probably better w/the SFA than IFS.
    Chris, are you making brackets for your 90? Or are you using ORU?
  11. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah so supposedly the axle is a Dana 60, but also isnt. The centersection is all D60, but the knuckles and such arent, the guy at Dynatrac called it a Hybrid 60, sooo the hub conversion wont work because the knuckes arent Dana. I guess its the D60s '00 and up, because its avaliable for the 60s between '9? and '99, so hes stuck with the 3pc axle. As for steering ORU says they can make it work, guess thats good news.
  12. bluejeep
    Jan 9, 2004
    106
    Des Moines, IA
    I believe you can use all ford balljoint outers on the dodge axle if you want. That would give you manual hubs, a real spindle with seviceable tapered bearings, and options of Yukon 4340 35 spline stub axles.
    Rod -- yep, I'm making them. Since I do fab work it would be just wrong for me to buy them. I've just got to pick up my 4.10 14 bolt sometime and I'm ready to start on it.
  13. the cork
    the cork 1/2 ton status
    Apr 20, 2003
    128
    mid west,
    your best bet would be to use a 78-79 ford dana 60,
    its high pinion, and the springs are farther away from the
    tires ( more clearance), = less rubbing, they say, /forums/images/graemlins/usaflag.gif
  14. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    The Ford ball joint stuff won't work on the later ( 2000 or so to 2002 ) Dodge front 60's - they have the ball-joints in the "C" that is attatched to the tube not the knuckle . The last few years of Dodge 60's are gay and the usual up-grade stuff won't work on them .
    HTH , Tom
  15. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Hub bearings do fail with big tires but then again you can run a detroit or other locker up front and manually disco the cad using a posilock cable instead of the vacuum. Then it would be like a selectible ARB.
  16. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Well, not quite like having an ARB. If you have a locked front and disconnect one side (by either unlocking a hub or by the axle disconnect) you will always send power to the opposite side. I've seen several guys do this on the trail due to breakage and it causes some weird handling and pulling to the side.
  17. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    As I said above, the 2000 and up knuckles arent Dana, only the centersection is, therefore, Dana parts wont work for it. Tires wont hit the springs, because id put them 32.5" center to center. I dont think were gonna use the axle anyway, because its too much to machine the knuckle for steering. Unless someone knows a place besides ORU that knows what there doing?
