Will a dodge dana 60 work?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Apr 30, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Will a dana 60 out of a dodge work for the front of my Chevy?
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    yes, Mudhog(Shannon) has one in his.
  3. reddog64
    Nov 9, 2000
    3,325
    what is different about it and the "chevy" one? any different components needed... did dodge make there's with 4.10, 3.73, etc???
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    the soring pads are 1/2" off so the springs have to be played with to bolt up, or you can space the spring bushings.
    The gears and lockers I believe are the same, but the shafts and outs stuff is different.
    Not sure on the steering stuff. Shannon will know.
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes it will i have one in mine /forums/images/icons/smile.gif the spring pearches are slightly off but all you need to do is spreed the springs a little and it fits fine /forums/images/icons/smile.gif you will need chevy spring plates if you want to run the sway bar you will also need a chevy steering arm ($40 locally) and a chevy yoke for the drive line ($25 locally)
