Will a Dually Rear Axle fit a 3/4T Truck?
Discussion in 'The Garage' started by Looksback, Mar 29, 2003.
  1. Looksback
    Looksback 1/2 ton status
    Aug 12, 2002
    120
    Montana
    I have a 3/4T truck and I was woundering would a 1 ton dual tire axle fit on my truck with no modifcations, or would something have to be changed?
    Thanks for the help
    LooksBack
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Nope, spring perch and shock mounts will be different.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    What Bad Dog said..... /forums/images/graemlins/wink.gif
  4. Looksback
    Aug 12, 2002
    120
    Montana
    I think I know the answer but I will ask anyway, can the springs be modified?
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You would have to swap the spring hangers out with 1 ton ones. They are rivited on. Not too fun if you ask me. I would rather move the perches.
  6. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Yea move the perches Why do you want to run the D70 are you gonna run duals? If your planning on running SRW there gonna stick out like 2more inches on each side
  7. Looksback
    Aug 12, 2002
    120
    Montana
    I gott a '78 4.56:1 dually axle, thought it might be something I would try maybe in the future. I do not have a single rear tire 1 ton axle and I do not know anyone that does, so that why have not given that any thought.
    Will a single rear tire 1 ton axle bolt right in place? and if the ratio's do not match can the gears from the 3/4t axle be used in the 1 ton?
    Thanks for the help
    LooksBack
