Will a fasttrack fit?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by ecameron87, Feb 22, 2006.
  1. ecameron87
    ecameron87 1/2 ton status
    Nov 9, 2002
    115
    AZ, Tucson
    I am looking into getting a fasttract soft top for my 72 K5. The only thing is that I have recently installed a family style roll cage. You can see it here:
    http://www.wheelingarizona.com/forums/viewtopic.php?t=6377
    We fabbed it together with the top on so a hardtop fits perfectly.
    Will a soft top fit?
    Will I have troubles when I go to take the soft top down, or in other
    words, will the hoops fold backwards without interfering with the cage?
    How loud is the hard top when cruising?
    Does anyone run A/C with the soft top on? How well does it work?
    Thanks for your help.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Ya I think it will work..but! you may not beable to use the two front bows...the most important bow in the rear one and it looks like it will clear your cage at the back...the center it is hard to say if it will beable to go over your cage...prolly not..
    I have a 6pt cage in mine w/ fastrac top
    I could not use the front bow..no biggie really
    See the back goes all the way back to above the gate
    Hope this helps....
  3. ecameron87
    Nov 9, 2002
    115
    AZ, Tucson
    Yeah, the pics help a lot. I have been looking at your setup in a previous post, Burt, which is why I was thinking about getting a soft top again. It looks like they used 3/4 conduit to make the hoops. I wonder if I could re-bend some new hoops to make it fit. Make is slightly longer/taller. It should be a pretty cheap fix. This might be a way to get it to fit tighter as well. I did this once with a Samurai soft top and it worked great.
    Thanks for the pics.
  4. Burt4x4
    6,854
    Ya probly would work. You could do it on a hot sunny day with the top nice and warm so it streaches. Once you get it on nice and snug leave it on for a few days so the material 'seats' in...could work:D
  5. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    hostly I"m going to say it's not going to fit. that's the boat I"m in now with mine is we built the family cage within an inch of the double wall top and it's too tall or the soft top. The fabric may stretch some but not that much, especially with the windows in. So I'm going to cut my cage down slightly so it will fit.
  6. Burt4x4
    6,854
    I agree you will not know for sure until you have the top.
    If you are willing to change your cage to fit the top I would get the top first so you know exactly what changes to make :D
    One detail I left out is without the front bow installed I cannot use the window frameing that the top came with....for me this is fine as I don't care much for all that extra hardware..
    Good Luck
    Burt
