will a fixed yolk of the rear of a 203 fit on a 205
Discussion in 'The Garage' started by highrider_44s, Apr 14, 2005.
  1. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    does anybody know if the spline count and shaft size are the same on the rear yolk a 203 and a 205
  2. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    The shaft, or the yoke itself?
    The Yokes will swap, they are the same spline size and count, as well as ground hub diameter.
    If you mean can you convert a slip yoke 205 to a fixed using NP203 part, no it will not work. The internals of a NP203 are far far different than what is required to do that swap.
    -Kyle
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Yokes swap back and forth.
  4. highrider_44s
    Mar 28, 2004
    392
    southern B.C.
    thanks guyz thats what i wanted to know now all i got to do is find a socket big enough to take it off :D
  5. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    It 1 5/16" if you didn't already know. I bought a craftsman one but the socket walls were too thick to get into the yoke, I ended up picking up a cheapo made in india one that had thinner walls, it worked fine, at about half the cost of the Craftsman.
