Will a full size p/u fit on a u-haul tow dolly?
Discussion in 'The Garage' started by muddin4fun, May 3, 2003.
  1. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Anybody know? /forums/images/graemlins/ears.gif
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    A K5 won't, so since the full size pickup is the same width, then it won't fit either. /forums/images/graemlins/frown.gif
  3. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Are phords narrower at all? Cause that's what I'll be pulling
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Can't help with that. I dumped my last Ferd in 1980. Haven't owned one since!
  5. Toledo
    Toledo 1/2 ton status
    Dec 10, 2001
    207
    College Station, TX--DeRidder, LA
    Are you talkin about the drive on or just the two front wheels. I pulled my truck from St Petersburg, Florida to the Texas line on the drive on one. Used stock GM 8 lug steel wheels with real small tires and aired em down after I got it on.
  6. BAD4WD
    BAD4WD Registered Member
    Feb 4, 2002
    63
    Sonora
    Yes, they will fit, with only the stock rims & tires. Just strap them down over the axle tubes instead of the tires.You might scratch your hubs a little.
    My local U-haul has two diff. dollys one is a little bigger. Laters /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif
  7. bigjbear
    Feb 18, 2000
    13,699
    155
    Marietta GA
    Fords are wider. The trailer we put my K30 on was too narrow to haul an F250 w/ a TTB front axle.
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I tried to rent a U-Haul trailer a while back to tow a parts truck.
    The person on the phone asked me several questions...
    "Does your vehicle have a weight distributing hitch?"
    Yes.
    "What are you towing?"
    85 Chevy 3/4-ton 2wd... unladen, less engine
    <long pause>
    "Sorry... we don't have anything for you."
    What about those flatbed tandem trailers you have with surge brakes?
    "They're not meant for anything that large"
    /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/rolleyes.gif
    Granted, I was unprepared for this line of questioning. Things have changed from the time you could just show up with cash in-hand and drive away with a trailer for the day. (Or maybe you can still do this at some places)
    Next time you can be certain I'll be towing a Pontiac Firefly /forums/images/graemlins/tongue.gif
  9. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    I will tell you about my adventures with Uhaul. I rented a tandem axle trailer from them to tow the blazer from Wa. to Moab, about 1200mi. one way. I had a hell of a time getting it to fit between the fenders even with small a$$ tires on the front. The hubs were hanging up on the fenders. /forums/images/graemlins/eek.gifAlso after total desperation and the 4th Uhaul store the K5 turned into a CJ5 /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
    I will have to say the trailer did ok on that trip but I think I would not do it again(I'm looking to buy my own trailer)
    I have also pulled their dollys. I have pulled a Datsun very very good idea /forums/images/graemlins/thumb.gifMore recently I pulled a '82 K20 /forums/images/graemlins/truck.gif, very very very BAD idea! /forums/images/graemlins/eek.gifWhen they say do NOT back up they mean it! I put the rear on the dolly as it is narrower, still not a good idea. I only had about 10mi. to go and I was thinking I wanted to take it half that distance.
    So there is my Uhaul experances, take them as you will, and stay off the roads when you see me at your local Uhaul. /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
  10. 2Dogs
    2Dogs 1/2 ton status
    May 4, 2001
    3,428
    Sunnyvale Ca
    Did the U-Haul full trailer with the Blazer on it from Dallas to Portland.
  11. bigjbear
    Feb 18, 2000
    13,699
    155
    Marietta GA
    Tell them it's a '92 Pontiac B'ville. It will get you the right width w/o the hassle. You will still need stock size tires, though
  12. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    By towing something other than the specified vehicle on the rental contract you void the contract (and insurance) and you can't even imagine the consequences if anything bad happens. All the questions they ask are for a reason. Don't screw with them. I won't tell you where I work, but I will tell you I'm sick & tired of going to court over this exact topic. Rent safe, or use somebody other than U-Haul!
  13. 77ChevyK10
    77ChevyK10 1/2 ton status
    Feb 2, 2003
    317
    Laveen, AZ
    I got the trailer not the car dolly and it was a B**th to get the thing from U-Haul. I took it 150mi one way. Come to find the K10 4x4 shortBed did not fit in the rails. So puck it up from the front with a backhoe and set it on. It bent the rail out.
  14. bigjbear
    Feb 18, 2000
    13,699
    155
    Marietta GA
    Don't want to start a flame war, but renting a trailer is one of the biggest PITA out there. If I wreck it, my bad, I pay. Maybe I'm just not letigious (is that a word? if it is I'm sure I spelled it wrong) enough for the modern world.
  15. Polaris
    Polaris 1/2 ton status
    May 30, 2002
    1,182
    Rhinelander, Wisconsin
    What BAD4WD said, it will with stock rims & tires only. It's tight but it will work. I did put my Blazer on one once but had to drive over the fenders and felt bad about it. My hubby is a U-Haul dealer, so I haven't had any problem renting from them /forums/images/graemlins/smirk.gif
  16. DougK20
    Feb 18, 2003
    384
    Boise, ID
    You're missing the big picture. There are weight and size restrictions for a reason. Kill yourself off-road if you want. But, please take into consideration the OTHER drivers on-road. Thanks.
  17. bigjbear
    Feb 18, 2000
    13,699
    155
    Marietta GA
    OK, but when it fits onto the trailer and is within the weight limit whats the big deal?
  18. muddysub
    muddysub I Staff Member Moderator GMOTM Winner
    Jun 23, 2001
    10,247
    90
    my garage, Henderson, NV
    my little gmc c-1500 2dr short bed fits on a uhaul trailer. we told them we were towing an s10.
  19. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,153
    24
    Stevens Pass Highway, WA
    Just put small tires on the front and if you have to let some air out of the tires (watch that they dont have a slow leak or the straps will get loose on you). I have hauled many full size trucks with Uhaul tow dolleys and the only time I had a problem was trying to turn around on a dead end street with that 66 GMC (it wasnt running at the time to unload it).
  20. muddinmike
    muddinmike Registered Member
    Jan 7, 2002
    30
    Boise ID
    So why doesnt u-haul just get some damn trailers that you can load a fullsize on? obviusly they would stay rented out just fine............
