Will a NV4500 bolt into where a SM465 was?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79ChevySB, Apr 7, 2002.
  1. 79ChevySB
    79ChevySB 1/2 ton status
    Jul 8, 2001
    178
    Denver CO
    I just did a search on the 4500 and didnt see this, so I'll post the question. Will the 4500 bolt into where a 465 was? Do you have to change out the bellhousings? Anything else to change out? Thanks guys.
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I am pretty certain that the input shaft is the same so you can keep your clutch...But I am pretty sure the bellhousing bolt pattern is different...depending on what t-case you are running, you may need a custom tailhousing from www.advanceadapters.com What t-cases did the GM 4500 come mounted to from the factory? Were they the 241HD's? I can't remember...I would probably require some work to get the 4500 to work with a 205 t-case....
    Chris
  3. lt1yj
    lt1yj 1/2 ton status
    Oct 7, 2001
    101
    Near Chicago, IL
    I think the NV4500 is a little longer than the 435 and the trans bellhousing pattern is different. There are 2 patterns used on the Chevy, I don't know the year splits.
    GM put 241HD's and a Borg Warner Transfer case behind the NV4500.
    The round pattern 205 with the 32 spline input shaft can be adapted to the NV4500 with a little grinding on the tail housing to clear the shift rail on the 205. Advance Adapters has a pretty good listing of the NV4500 to 205 conversion on thier website.
  4. dyeager535
    26,979
  5. 79ChevySB
    Jul 8, 2001
    178
    Denver CO
    Thanks guys for the input.
  6. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Theres a factory Dodge housing adapter that will allow you to bolt a 205 to a NV4500 so you dont need an expensive adapter from Advance Adapters. They have a great book on how to swap in a 4500 without using they're stuff. It has a ton of info
