will a short shaft from 700R4 fit a 2wd trans?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Aug 19, 2002.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    A member is selling one on the for sale saction that Im interested in but i need to know if it will work in the 2wd trans that i have from an 85 silverado. Im not sure what year the shaft is coming from. He says it will fit with my 203, hes just not sure about the 2wd trans.
  2. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    I think the 2 wd shaft is longer!!
    just not 100% sure
  3. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    to put the 700r4 trans from a 2wd into a 4wd you need a shorter shaft. advance adapters makes one but im wondering if one out of a 4x4 700 would fit into a 2wd 700. so you end up with a short tail shaft
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The only difference between a 2wd and 4wd transmission is the 4x4 cases are thicker and use an aluminum inspection cover with 3/8" bolts rather than sheetmetal screws, and also the output shaft on a 4x4 is shorter than a 2wd. To answer your question you may install a 4x4 shaft into a 2wd case and use it in a 4x4. You could also do it the other way around and install a 2wd shaft in a 4x4 case and use it in a car.
