Will a Suburbans rear axle fit under my K5
Discussion in 'The Garage' started by DUKE, Oct 1, 2002.
  1. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    I know it will fit, but do I have to relocate anything? I would hope that it should bolt up perfectly. The local yard has a set of axles (havent seen em yet so I coundt measure it all out. What is going to be instore for me when I swap em out?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Should be a direct bolt in if its a 3/4 burb. 1ton rear axle will have a different perch width. I believe you will need different u-joints for both front and rear(someone will correct me on that if i'm wrong)
  3. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    thanks, yeah they are 3/4ton axles, sorry. Do you mean different u joints than before or front and rear u-joint are different from eachother?
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I believe (not 100% sure) that the 1/2 ton and 3/4 ton u-joints are different, so you would need a trick u-joint which you can actually buy from napa, cause your front and rear shafts will be 1/2ton and your axles will be 3/4ton. But now that I am thinking about this, i don't think the front axle driveshaft ujoint will have to change, i do know the rear will. Someone jump in and say something if i'm wrong.
  5. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Front should be the same. Your rear U-joint on the rear shaft will have to be swapped to a conversion joint. Your 1/2 ton has a 1310 yoke and the sub axle will have a 1350 yoke. Your emergency brake hook up might be different as well. Depending on the year model the banjo bolts in the calipers switched from Imperial to metric as well. All are minor problems that a trip to the parts house can fix
