will a tie rod end work as a draglink end??
Discussion in 'The Garage' started by protechk5, Apr 7, 2005.
  1. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    Can I use a tie rod end as a draglink end??
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Tierod ends have a different taper in the hole then DLE's. A TRE will fit in a DLE hole but it should not be done unless it is a last ditch effort to get off a trail and home or something.
    Harley
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    what about the companies selling TRE for thier drag links in crossover kits? i thought they were the same.
  4. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    On my crossover, I used identical right hand threaded TREs on the draglink. They are the same as the rh TRE on my Tie rod, so spares are easy to find. By using the TRE's on a draglink, they are stronger and tighter then the 2 year old DLE's I took off.
    I'm not quite as hardcore as some guys here, but some one ton guys with like 40's and up have bent stock DLE's in a crossover setup.
    I'm using an ORD arm and a superlift dropped pitman arm.
    Blake
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    The size of the stud on a DLE is larger than a TRE. They use the same taper. So if you've got a 1.5/12 reamer you can ream out a TRE hole and put a DLE in it.
    You can't put a TRE in a hole a DLE was in.
    DLEs have a greater angle of operation than a TRE by a significant amount.
    I'm using TREs on my draglink for crossover.
    Comparison between a DLE and a TRE
