Will all chevy 6lug fit chevys of 6lug?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Impex, Mar 23, 2000.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    Even if its a blazer, suburban, truck? Just as long as its 6 lug right?
    Make sense?
  2. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    if its the same generation then it should, but the newer, post-88/92 style, has a positive off set wheel, while the olders came with a 0 or slightly neg. offset wheel. so the newer may not clear the older, and the older may not clear the newer fenders, make sense?
    RaisedK5
    "Friends don't let friends drive Fords"
  3. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Also if your looking at puting on a set of rims from a new vehical you'll need to enlarge the center hole due to the different dia. of the holes.
    C'moe
    <font color=black>the blazer is "Back in Black"
  4. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Don't quote me on this, but I also heard that the new body style trucks (2000 series) have a different bolt circle. Might be worth checking about.
    [​IMG][​IMG]
    Durant, Ok
    '79 Blazer in progress
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    You will find some older 6 lug wheels from 2WD trucks with smaller center holes. The 16" wheels from the '88 - '98 body style have a different offset than the older trucks. I think they went back to 6 lugs on 2WD trucks again for '99, so those wheels may have small center holes as well as a different offset. Pretty sure that all 6 lug wheels are 6 on 5 1/2", including Nissan, Toyota (trucks and LandCruisers), and some others.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  6. 75K5
    75K5 1/2 ton status
    Mar 14, 2001
    268
    Michigan
    so If I found a set of 16" Rims from a 2000-2001 1500 series 4X4, would I have problems mounting them on my 75K5? What about the 99's?
    Thanks,
    Brian
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    Yes you will have problems... The newer ones have a lot of back spacing... Those wheels will run into your balljoints..
    If you want ot go 16", go aftermarket...
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "Pimpin aint easy!"
