Will an alignment cure my dog tracking?
Discussion in 'The Garage' started by hardcore_rob, Jan 14, 2003.
  1. hardcore_rob
    hardcore_rob 1/2 ton status
    Dec 6, 2002
    111
    Colorado Springs, Colorado
    People keep telling me my truck is dog tracking, I assume it needs a 4 wheel alignment to cure this since, it has happened since i put my lift on.
    Am i right in thinking this? Or is there something else I need to do to stop the truck from doing this. From what i can tell, measurements are very close, doesnt seem to bee off very much.
  2. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    Your rear axle is actually 3" shorter than the front so it appears that it is.
    Chris
  3. hardcore_rob
    Dec 6, 2002
    111
    so it might not be dog tracking after all? or appears that it has the right measurements? dog tracking should be noticble am i correct? it seems to be pretty straight when i drive...
  4. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    For the most part, I beleive all 4x4's dog track. However, when trucks are lifted and have bigger tires, it seems to be more noticible. I wouldn't worry about it. /forums/images/graemlins/burb.gif /forums/images/graemlins/thumb.gif
  5. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    The rear axle is 3" Narrower than the front axle. (1.5" on each side) This causes a look of dog tracking when viewed from behind. All of the solid axle chevys did it.
  6. evilandangry
    evilandangry 1/2 ton status
    Dec 29, 2002
    105
    Norwood, NJ
    If you just lifted the truck with rear lift blocks you may have a centering pin problem on the rear axle. measure down from the front eye of the rear spring to the front of the lift block. do this on both sides and compair the measurement. If the difference is more than a fraction you may have the spring centering pin in the wrong hole in the lift block. This is very easy to do, (ask me how I know!) and will cause moderate dog tracking.
  7. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I get that all the time but I tell people to look at the body line, not the tires and then it looks better to them. It's because of the axle widths.
  8. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> It's pretty easy to tell if it's actually dogtracking, just spray the street down in front of your house with water then drive the truck straight through it fairly slowly. You'll be able to see all of the wet tire prints and easily determine if it is tracking crooked or not. </font color>
  9. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Better yet...grab a tape measure and measure the wheelbase on both sides of the truck. If it's dog tracking it will be significantly different on one side. K5's should be awefully close to 106.5"
    Rene
  10. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    What's dog tracking?
  11. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    Looking for a dog with a gps tracking system.... /forums/images/graemlins/grin.gif j/k
    Dog tracking would be when your truck is driving down the road croocked. Like the truck is pointing at a ditch but actually traveling down the road. Hope that helps.
  12. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I don't think it has to be all that different in order to drive crooked, besides that, what are you going to use as a baseline to measure from? The hubs are too deep in the wheels, and the tae would have to bend around the tire to get to the rim. the tire seems like a poor place to measure to... To do it accurately you'd have to pull the tires off and put the thing on jackstands, but it would have to be supported evenly from all 4 corners so the suspension was perfectly level. Just seems easier to hose down the street and look at the tracks.</font color>
  13. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Measure from the back of one to the front of the other...simple. You're not looking for accurate wheelbase, just a good comparison from one side to the other. I had a spring center pin break a long time ago...the wheelbase was off by over an inch from one side to the other.
    Most of the problem here is it rains often enough that using wet pavement is impractical.../forums/images/graemlins/grin.gif
    Rene
  14. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yikes, it was off by an inch!? I gotta think that you felt that in the seat of the pants... I noticed that my truck started tracking crooked about a year before it was parked, when I put the 14b in I found out it was because the right side spring pin was completely sheared off and that side of the axle had moved forward about 1/4". </font color>
