Will bleach ruin seat belts?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 72Blazerod, May 20, 2002.
  1. 72Blazerod
    72Blazerod 1/2 ton status
    May 18, 2000
    264
    Vancouver, British Columbia, Canada
    Hi guys,
    I just got some white seat belts for free but the have mildew stains (the donor truck was leaky). I was wondering if bleach would break down the fibres like it does to cotton? Any info is appreciated.
    Rod
  2. Marc72
    Marc72 Registered Member
    Apr 9, 2001
    11
    Austin, TX
    Well... I have white seatbelts as well and I bleached them. There is no damage at all that I can see, but it didn't work terribly well - I really had to soak 'em for a long time. I'm pretty sure that the synthetic material is pretty bleach resistant so I wouldn't worry.
    However, I must warn you that if you have black carpet and your top leaks a little bit like mine does, the dye from the carpet will stain the belts if you leave them hanging on the carpet...
  3. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    I think seat belts are made out of nylon and bleach can weaken nylon ... but you won't know if it did until you need them most. I wouldn't do it.
  4. Marc72
    Apr 9, 2001
    11
    Austin, TX
    I think in the 70's they switched to polyester but either way, rampage is probably right that it could weaken the belt. You might try to use an oxygen bleach like Oxyclean.
  5. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    Mine are half blue and half brown. I scrubbed mine with Simple Green and a nylon brush. Worked pretty well. Try OxyClean too, heard good things about it.
