Will Burban Axles fit in my Blazer *Another ?*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SAVAGE1, Mar 12, 2001.
  1. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I found a guy who is willing to trade axles with me. He's got an 85 3/4 ton Sub and my K5 is the same year. I'm pretty sure its a compatible swap but just wanted to check with you guys first. Any problems to look for? Thanks in advance.
    Rod
    <P ID="edit"><FONT SIZE=-1>Edited by SAVAGE1 on 03/12/01 06:14 PM (server time).</FONT></P>
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Re: Will Burban Axles fit in my Blazer
    Not an expert, but you may need the converter cause I think the U Joints on the 3/4 tons are bigger. Other than that, just look for the same Gear ratio.
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Yep they'll bolt up. Add a hybrid u-joint (Napa part # 447) and your K5 and your done.</font color=blue>
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You'll actually need 2 of those conversion u-joints. One for your K5 and another for your buddy's Suburban, assuming he wants to drive it home. [​IMG]
  5. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    Good point about the u-joints. Both our rigs are daily drivers. So everything else is just a typical swap? Thanks for the feedback.
  6. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    I just talked to the guy and he said its an 8 lug semi floater. I thought semi floaters are 6 lug. I still want to go through with the swap because I really need the 4.10 gears. Is the semi floater any good. My rig is a daily driver and I don't do any extreme crawling. I can always find a 14b FF later anyway. Watcha guys think?
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    The semi-floater is not nearly as strong as the FF but it is lighter and has more clearance. This is what is often found in 3/4 tons. I think it is supposed to be somewhere between a 12 bolt and a Dana 60 strength wise (closer to the 12 bolt?). Still a good upgrade. If you don't run huge tires it is better due to the clearance and weight. Biggest problem is that if you snap an axle, you can loose a wheel depending on where it breaks.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I'm pretty sure that you're looking at an easy swap, especially since they're the same model years. I did this years ago, between a '75 K5 and a '74 K25. Did the whole thing, by myself, in the parking lot of an apartment complex in a day. (Let me assure you that a 14-bolt full floater is one heavy mutha!) [​IMG]
  9. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    Thanks guys, I'll let ya know how it goes.
