Will Dirty O2 sensor cause erradic Idle?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chrome Moly, Sep 23, 2000.
  1. Chrome Moly
    Chrome Moly Registered Member
    59
    Cheesehead Wisconsin
    Hey gents, Just wanted to know if a dirty 02 sensor will cause an erradic idle?
    Thanx in advance.
    Chrome Moly
    <font color=green>Resistance is Futile</font color=green> [​IMG]
  2. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    No...lose of fuel mileage. Check for vacum leaks...check egr with Mity Vac and see if it holds vacum and kills engine at idle....remove and clean IAC motor....and check tbi mounting gasket and for loose bolts.
    AZBLAZER
    1979 K5
    1976 K5 Chalet
    1972 K10 Suburban
  3. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    my idle was not steady just before the temp sensor in top of manifold went totally flakey.
    SteveB
  4. River
    River 1/2 ton status
    May 8, 2000
    121
    Amstelveen, Netherlands
    Same happend to me, also the coolant temp sensor.
    Greetings from Amsterdam,
    River `90 K5, 350, TH700R4, NP241, "33, 3.08, 10 bolt F, 10 Bolt R(GOV-Lock)
  5. Steve_87K5
    May 26, 2000
    521
    central NC
    Hi River! when the temp sensor went bad, my exhaust went black and plugs fouled. Computer thought it was very very cold.
    SteveB
  6. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    Dirty? MY O2 sensor has a thick layer of baked-on mud. If you mean fouled, yes, that can affect idle. But I would suspect other components first, unless you are getting an O2 lean or O2 rich code. R u getting any codes?
    Squash
    http://www.trailrunners4x4.org/users/realsquash
  7. River
    May 8, 2000
    121
    Steve my idle just kept going from 600 rpm to 1800 rpm up and down think their was a loose contact or something inside the coolant sensor. Service engine soon light came on also. Replaced the coolant sensor and evrything was fine again.
  8. Chrome Moly
    59
    Where is the Temp sensor located? And how much is it?
    Chrome Moly
  9. Chili 87 K5
    Chili 87 K5 Registered Member
    May 8, 2000
    29
    CO
    The coolant temp sensor is located at the front of the intake manifold. The actual sensor unit is mounted inside the coolant passage, and has a hex nipple adapter which seats it into the coolant stream. There is a plug-in wiring harness connector that hooks it up to the ECM.
    PS; the sensor is supposed to be pretty sensitive, so fix it or break it, I say!
    Hope this helps!!
    Brian 'Chili' G.
  10. hpfire7227
    hpfire7227 Registered Member
    Mar 14, 2000
    75
    Holland Patent, NY
    I had pretty much the same problem, replaced the CTS and nothing happened. I'm still trying to figure it out. I'll let you know what happens.
    10 BOLTS O' FUN
  11. realsquash
    Jul 12, 2000
    778
    SE WI
  12. Chrome Moly
    59
    Idles @ 800 and then shoots up to 1900 rpm at a complete stop.
    Chrome Moly
  13. slodawg
    slodawg 1/2 ton status
    Apr 30, 2000
    190
    Southern Arkansas
    Hey I hate to even say this but my dads got a 89 F@rd pickup and his is doing the same thing. idle low then go way up. The guy at the ford place said it could be his catalytic converter stopped up not letting the engine breath and exhale right. I dont know if that could cause this or not being as NOTHING I've EVER owned has had one on it. The temp guage has been going crazy lately and he aint thought nothing about that. Maybe this is the culprit. Good to see what ya'll come up with.
    <font color=blue>SLODAWG</font color=blue>
    http://www.slodawg.coloradok5.com
