Will F*rd D60 hubs fit my chevy D60
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by arq, Aug 10, 2002.
  1. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i found a Furd d60. i was wondering if the hubs/locking hubs/etc will fit my chevy D60??
    ARQ.
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    I DONO , but david would want it for hi jeep !!
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    lets go get it. it's just down the street /forums/images/icons/smile.gif it has a high angle pumpkin
    ARQ.
  4. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    The majority of parts from the Ford axle will not interchange with a Chevy axle. I bought one once only to find that the locking hubs, diff cover, carrier, yoke and bearings were the only parts that would swap.
    Specifically, the bearing hubs are almost an inch shorter (from seal to lock out) than Chevy hubs. Whcih makes the stub axles and (5 bolt) spindles shorter too.
    I'd still get it, the high pinion stuff is cool or it's a very valuable part to make some money on.
  5. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    You will have to swap from the outer knuckes out. The inner knuckles are the same. I thought I read somewhere that you could redrill the knuckles for the different spindle pattern.
