Will Ford ATF hurt GM trans??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by creampuff90k5, Feb 19, 2003.
  1. creampuff90k5
    creampuff90k5 1/2 ton status
    Feb 15, 2002
    142
    New Jersey
    The other day when changing the fluid and filter on my 700R4, I accidently added a quart of Ford ATF along with the other four quarts of Dexron III/Mercon. The ford stuff was on the same garage shelf - left over from an old mustang project. Anyway, is this going to hurt anything? The truck seems to drive fine, but as much as I don't want to take the pan down again, this mistake is kinda bugging me... Am I just paranoid?
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    You will be fine as long as it was ATF and not somethin else /forums/images/graemlins/thumb.gif
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I think the ATF+3 for chryslers is what you need to worry about, dont fords use dexron also?
  4. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    Dextron III...
    7.5wt..Loaded with friction modifiers for a smooth shift, and to reduce lock-up shudder
    Ford Type FA
    10wt...Not as many friction modifiers, but has some for lock-up converters to prevent shudder--Most European cars now.
    Ford Type F
    10wt...NOt as many friction modifiers, NO addatives for the converter..not used in anything OEM
    1qt out of 10 to 12 will make absoultely NO difference...all the additives you will ever need are in the other 9-11qts
    Ford Type F is recommended by B&M, if you don't want to spend $7.00 a qt for their fluid..It shifts better..fewer adatives to make it slip...
    I use it in my TH400 (no lock-up)
    You can use Type FA with a lock-up
    All Fords, after about 1985, and ANY that have been rebuilt are recommended with Dextron...It is to make them shift smoother...The C5, with a lock-up uses FA or Dextron III
    I am factory certified in these transmissions
    PowerGlide/TurboGlide/Th350-350c-375/Th400-475/Th200-200r4/Th700r4...Ford C3/C4/C6/AOD/A4LD/(fwd)AXOD/ATX and some others
    I haven't done transmissins regularly since about 1986, but I am still current
    /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
  5. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    Type "F" Ford fluid improves clutch holding power & shift firmness. I routinely use type "F" fluid in my performance builds on GM transmissions. I do not really recommended to mix the 2, but there should be no adverse reaction from adding 1 quart to your trans.
  6. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Did you used to be a Ford tech?
    I was a Ford auto trans tech for 8 years.I was certified in alot of different areas but ATs were my specialty.I was goin for Master Tech so I could get that cool little statue /forums/images/graemlins/grin.gif
  7. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Shouldn't be a problem, adding a quart to a GM tranny tends to have about the same effect as the B&amp;M Trick Shift stuff, but for alot less money. /forums/images/graemlins/thumb.gif</font>
  8. creampuff90k5
    Feb 15, 2002
    142
    New Jersey
    Thanks for your help everyone. Based on the advice, I have decided to just leave it alone. By the way, the odd quart of fluid was Ford Type F... got lucky I guess!
  9. the professor
    Feb 6, 2003
    130
    To frizzlefry:
    mostly Lincoln/Mercury in my last 6 years...although I did work at Ford prior to that
    We rarely did trucks, except for the occasional light p'up or recall on a commercial van or p'up
    I got away from AT's, in about 1986, because I hate to work on FWD..went to EEC specialist..I still did transmissions occasionaly when the trans guy got sick or overloaded...(under much protest)
    To bad Ford stopped the Ford Dinners, got to know techs from all over..
    Might even have seen you at school, if you were closer, but I went out on med dissablilty in 1996, so maby not
    .. /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
  10. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I loved AXOD/Es,I made ALOT of $$ off of those
    I could have one out of the car and apart on the bench in about 50 minutes /forums/images/graemlins/grin.gif Those were easy 13-17 hour warranty paying tickets.
    Now 6 cyl Contours and Mystiques,I was lucky to get out in 2-3 hours and they didnt pay $hit /forums/images/graemlins/grin.gif
  11. BanksBurban
    BanksBurban Registered Member
    Mar 23, 2002
    88
    New Jersey
    I'm having the 400 in my Burb rebuilt. Should I tell him to fill it with Type F? Will it reduce wear on the clutches and make the trans last longer?
