Will GM 6ft Bed Quarter match K5 Rear Quarter?
Discussion in 'The Garage' started by Joe Kitzmiller, Nov 22, 2005.
  1. Joe Kitzmiller
    Joe Kitzmiller Registered Member
    Dec 20, 2004
    25
    West Virginia
    Would the skin from a 6ft gm truck bed match with blazer rear quarter panel? Ever do it before and how did it turn out? Seems like it would be easier to cut the skin from the 6ft gm truck bed and match it to the blazer rear quarter panel. That way you dont have to replace the whole panel with foreign steel and keep it OEM.
  2. HillJackCustoms
    HillJackCustoms Registered Member
    Apr 19, 2005
    64
    Indiana
    wow u read my mind, i was just gonna post the same things... I got 2 rear bed sides that are trimmed out, i wanna make it look stock again...
  3. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    I would be surprised it they did. We swapped a pickup cab onto my buddies K5 frame, and there's definitely less space between the rear wheel and the door on a K5.
    I suppose you could trim them to fit.
  4. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    On our 72 k-5 we were going to buy shortbed bedsides, and then cut and weld in the door jamb. I have heard of others doing this. I can't see why it wouldn't work. I believe the difference is between the door and the tire, not the tire to the tailgate.
  5. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Lots do this since quarters are getting hard to come by. Just need to trim side by door a bit shorter, otherwise same everything.
  6. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    aside from blazer being shorter the gas filler is in the wrong spot and youll have to figure out the top bed rail to to bolt your top back on. other than that i cant think of anything else.
    balzer
  7. Joe Kitzmiller
    Dec 20, 2004
    25
    West Virginia
    RE:Cornfield Creations
    If the distance from the outside of the tailgate to the centerline of the rear is the same then the quarters will match. But will the gas filler hole match up? Which may not be a problem.
    What i'm propossing to do is leave the blazer top rail, tailgate and door posts inplace. Then remove the outer skin off of the quarter except in those areas previously mentioned.
  8. HillJackCustoms
    Apr 19, 2005
    64
    Indiana
    where would you get bedsides at?
  9. Joe Kitzmiller
    Dec 20, 2004
    25
    West Virginia
    buy the truck bed as a whole from salvage yard or individual.
