will hubs of a 10 bolt work on a 44???
Discussion in 'The Garage' started by twoslo4five0, Apr 2, 2007.
  1. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,615
    71
    Living in a dump, VA
    will the hubs and rotors from a 10 bolt fit on a 44????i have a set and my 44 ones need new rotors and berings...
  2. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Yes, they use the same outer stub shaft..
  3. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    Yep it all swaps over.
  4. dick_landy
    dick_landy Registered Member
    Mar 17, 2007
    82
    winnipeg,manitoba,canada
    i did the opposite- 44 hubs onto 10 bolt :D
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    If you're referring to the hub/rotor assembly it all depends on what year D44. There are two different spindles and the break is mid 76 and earlier and mid 76 and later. The only difference is the inner wheel bearing is larger (2" ID) on the later spindles and IIRC (1.75" ID) on the earlier spindles.
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    What he said^^^^^
    Ira
