will Hummer H2 wheels fit on a 14 FF?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 74 chev, Sep 30, 2004.
  1. 74 chev
    74 chev 1/2 ton status
    Sep 30, 2004
    159
    Concord,CA
    will Hummer H2 wheeels fit on a 14 bolt ff and HD 44?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Yes , saw the pics on here months back /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    $wheel and off road just did an article on this, they put them on a newrer dodge but they had the machine them, but they did mention that they should be able to fit on the older axels /forums/images/graemlins/dunno.gif
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    They will NOT fit on a 14bff, you will have to have the centers machined out to clear the hub.
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Does anyone know the the center hole diameter of the H2 rims...can someone take a pair of calipers and measure them?
  6. 74 chev
    Sep 30, 2004
    159
    Concord,CA
    how much would you have to machine out of them?
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    IF you have to, I'm trying to find out....thats why I'm trying to find out who has some H2 rims to take a pair of calipers to the center hole and measure it.
  8. 74 chev
    Sep 30, 2004
    159
    Concord,CA
    i was looking in some of the ebay auctions and some of the wheels were listed as a MM lug paterns and some were listed as 8 on 6.5 is this as issue too? im really interested on running these wheels with some 39.5 Iroks. machining them is not a problem it will just take more time that my truck is on jack stands.
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    That I couldn't tell ya about as I can't find any to look at to see. But I do know there are a few people on this site that are funning stock H2 rims on their rigs.
  10. 74 chev
    Sep 30, 2004
    159
    Concord,CA
    here is a pic of a wheel i found off of ebay it doesn't look like it would fit a 14 FF there also doesn't look to be much extra metal to take off.
  11. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    the 4 wheeler mag is in my truck ill go get it
  12. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ok they said that the rims are 4.6 inches but they had to bring them out to 5.155 inches to fit over thier 3/4 ton dodge ram hubs
  13. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    They will definitely fit on a FF14, or any other GM 8 lug axle. All GM 8 lug wheels including the H2s have the same bolt pattern, offset, and center hole diameter. They will not fit on a Dodge or Ford though without machining the center holes bigger.
  14. 74 chev
    Sep 30, 2004
    159
    Concord,CA
    what issue of 4 wheeler was this article in?
  15. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    last month oct 04
  16. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    They will NOT fit, there are alot of people on here that have tried this and they had to have the centers enlarged, the 14bff is the only one with the external "hub" so therefore it is the only GM axle that they wont fit.
    It doesnt take much to enlarge them since it is not very complicated, a machine shop shouldnt charge more than maybe 100 bucks to do it.
  17. Blazer1970
    1,600
    Old Mission, MI
    Respectfully, you are wrong. I just carried a 14FF hub with the brake drum attached into my basement and stuck in an H2 wheel, and it fits just fine. I repeat:
    ALL GM FACTORY 8 LUG WHEELS HAVE THE SAME BOLT PATTERN, CENTER HOLE DIAMETER, AND OFFSET.
  18. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    WRONG! very WRONG! Do it all the time.
    Here are pics to prove it. You can't possibly believe that all these guys that do this all the time are wrong.
    This is correct.
    Here's a quote from another forum [ QUOTE ]
    In order to install GM H2 wheels on a Dodge 3rd Gen truck, the center hole must be opened up accurately to 121.5mm or 4.774" diameter.
    The stock Dodge rims and the GM H2 rims are "hubcentric" meaning the rims are held on center on the spindle/hub by the center hole, not the lug nuts. There is only .007 diameter or .0035" per side clearance between the wheel and the spindle protrusion.
    About 1/8" per side or 1/4" diameter needs to me machined out, accurately. It can be done, tires off on a lathe, or as I have done, on a milling machine buy either manually boring or using an end mill and cutting a circle with a programmable milling machine (CNC).
    [/ QUOTE ] Dieselplace Post
  19. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ok well my bad, thats just what I have heard a few times.
    My mistake /forums/images/graemlins/bow.gif
  20. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    You really should be careful telling someone else something as fact when it something you "heard". /forums/images/graemlins/rolleyes.gif
    I can confirm that the H2 wheels WILL fit 14 BFF. I have them on my 97 K2500HD and my older 14 bolt on my Blazer.
