WILL I BREAK IT?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazing86, Feb 25, 2001.
  1. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    OK here it is, im getting a dana 60 for the rear, but i don't have the money to upgrade to a stronger axle for the front. Will i be okay (strength wise) with the stock 10 bolt. I will be running a 4in lift with 35's.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    well you might be ok what kind of wheeling do you do? are you hard on your truck or just light wheeling?
    s.smith 77blazer lookin 4 mud [​IMG]
  3. BlzrProne17
    BlzrProne17 Registered Member
    Nov 3, 2000
    27
    Wichita, Ks.
    The axle should be ok. I knew a guy that ran a 6" and 35" tires on a 10 bolt and didn't have any problems. I don't know a whole lot about this stuff yet but i'm just goin' from what i saw!
    Matt
    [​IMG] Call me a converted Bronco owner!! [​IMG]
  4. BlzrProne17
    Nov 3, 2000
    27
    Wichita, Ks.
    My friend (Blzr4x4ngkid) is in the same situation as you are. He is buying a 14 bolt FF for the rear and can't afford to buy a big front axle. Match the gearing on the front and rear axles. If you do rock-crawling, it's gonna break. If you go muddin' and you don't put a lot of friction on the tires and there's no pressure on the axle it won't break.
    Matt
