Will I Ever Find the Right Size Wheel Studs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by johnny reb, Apr 18, 2002.
  1. johnny reb
    johnny reb 1/2 ton status
    Mar 6, 2000
    326
    Pittsburgh, PA
    Bought 2 front rotors (w/o hubs) at Autozone for my 86 10-bolt. Rather than reusing the old studs I figured I would just get new ones. They look them up in their computer and bring out 1/2"-20 thread studs. Well, I have 7/16"-20 studs and lugs on there now. I tell them that the rotors and studs have never been changed and that 7/16" is stock. They tell me that the 1/2" is all they list for my truck. I reluctantly take the 1/2" studs and ended up buying 12 new 1/2" lug nuts to go with them. So I get home and pull one of the new studs through the new rotor using the washer and impact gun method as I have done many times in the past. The stud gets halfway in and the rotor cracks. So I take everything back to Autozne and tell them that there is no way these are the correct studs. They give me another rotor and I tell them to keep the studs, I'll look elsewhere. I go to 4-5 different parts stores and they all list 1/2"-20 studs and none of them fit into the rotor. I also ask them to pull out a rotor so I can compare it to the one I got at Autozone. Sure enough, they all match.
    So I go to a GM dealer. Take in the rotor and tell them that I need studs. They look up the studs and bring them out and although they are 7/16"-20 they still look like the seat is too big to fit in the rotor. So now I think, "This has to be the wrong rotor." But, of course, the dealer doesn't have a rotor I can compare mine to.
    I can't believe I'm having so much trouble finding the right studs. Anybody else ever have this problem?
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    went throught the same thing about a month ago..i even called up autozone and showed the manager where the p/n's between the manufacturer's book and the computer where wrong. for future reference...it is the 7/16"X20
  3. johnny reb
    Mar 6, 2000
    326
    Pittsburgh, PA
    I know it's the 7/16". Did they give you the wrong rotor too? What did you end up doing?
  4. txbluethunder
    Jan 29, 2002
    835
    Austin, TX
    i took them back the 1/2" studs and told the manager that his computer was wrong. asked him for the right studs and put them on. no probs...
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    I was looking around a couple of months ago trying to find a 1/2" stud that would actually fit in the front. I tried all the major chains, but nobody makes a stud that fits correctly through the rotor and hub in anything but 7/16". Even when I looked into drilling the holes out, I couldn't find anything with a length, knurl, cap, thread combination that would work. So I am running 7/16" in the front and 9/16" in the back.
    BTW, whenever I get funny part numbers from places like Autozone, I start trying different years of trucks that I know to be the same as mine. Many times, a different year will have a different part number that will be correct. I have also tried to get them to correct errors in the computer, but I think that it is handled nationally and they can't do anything about it. Just make a note for yourself so that you know what you need the next time.
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i just went through the same deal with napa. thing is they got it right on the first try. i dont like to go to napa because the prices. but they sell me the stuff at the "hoby shop" prices. this is for us, the local military. they have a book that has like a bunch(lots and lots , 200+) wheel studs in it. they can flip through, measure your old ones with calipers and then go from there. they got us new ones that worked perfect.
    grant
