Will I Run Into Problems Trying to Tow With Big Tires?
Discussion in 'The Garage' started by BrianDamage, Sep 22, 2005.
  1. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    Not worried about mileage or anything, but I hope to have 38's on my K5 in the near future (although..I was looking at some pics of someone's with 42's and it looked mighty sweet :thinking: ) .. . anyway, I want to be able to tow about a 14 foot trailer. 99% probaly only have a 4 wheeler on it. May have to occasionaly load it up with cnostruction-type materials.
    Am I going to run into problems trying to tow with tires that big ? Can I just run a dropped hitch and be cool ?
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    The only problem I have had with 35's is when pulling heavier loads on the highway. With a stock engine and 4.10's I could use more power. Other than that, I have had no problem at all. Just take it easy.
  3. BrianDamage
    May 14, 2001
    753
    Alabama
    cool . As long as it doesn't get all squirrely on me going down the road, I can handle that.
  4. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Do you have 63" springs in the back? That would make it real soft. With tires that big you'd probably need some sort of drop hitch.
  5. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    I'd definitly look into getting a decent tranny cooler. You might be alright with little loads but I'd rather put one in and have one less thing to think about.
  6. BrianDamage
    May 14, 2001
    753
    Alabama
    already got that put on when I had the tranny rebuilt :D
  7. jrpeebles
    jrpeebles Registered Member
    Jan 19, 2005
    40
    North Hollywood Ca.
    I have had the misfortune of towing many fullsize trucks on a trailer behind my 1 ton on 39" Boggers. The tall sidewalls seem to flex a fair amount, and tire wear is definately an issue. But with a little trailer and light loads you will be fine.
  8. cbbr
    Jul 17, 2004
    14,681
    I have an ORD shackle flip in the rear. The 63's would probably be a little soft.
  9. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Make sure you get a gear ratio that makes all happy (motor and tranny). Larger tires means lower gears to keep the equivilent performance. Also if you go big make sure you've got a good breaking system that can stop them and the trailer.
