will it ever stop? key stuck in ignition
Discussion in 'The Garage' started by surpip, Sep 14, 2006.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    damn, just got everything fixed, and drove the truck to work today, couldent turn the key off after i got back from lunch, had to pull the coil wire to shut it off
    any tricks to turn the ignition off and get the key out?
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    Wiggle it, which I'm positive you've tried, and spray some graphite lube in the keyway. Maybe pull on it with a pair of pliers too.
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Turn it like your trying to start it again sometimes that has worked for me.
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    npe that diddent work eaither
    guess i just need to take it apart
  5. Roland_Jenkins
    Roland_Jenkins Registered Member
    Apr 14, 2006
    58
    Newport Washington
    Disconnect the battery. Turn the key to the on position. Locate pin hole. Its either on the column near the ignition or you'll need to pop off the chrome ring surrounding the key.
    Straighten out a paper clip and stick it in the pin hole. Pull the tumbler out. Go to NAPA and get a new one.
  6. peterpan
    peterpan Registered Member
    Aug 18, 2006
    95
    WYOMING
    pin hole ??????? what year is it the pin hole thing is on 67 to 72 that i knew of if its 73 and up you will need to take the colmn apart to remove the cylinder
  7. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,026
    854
    Pinckney, MI
    Auto? try in different selections other then park.
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    89 k5 auto
    more on the pin hole?
    i was figuring on taking the thing apart
  9. 81K5GUY
    81K5GUY 1/2 ton status
    Jan 30, 2006
    943
    Rockingham ,N.C.
    push the shifter up harder into park and move the key at the same time.
  10. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    your year you need to pop the horn button. the pin hole is under there. I did this years ago when I swapped in a tilt column, so the exact details are lost. But at the very least start there.
  11. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    belive me i pushed the crap out of the shifter
