will it fit in my garage?
Discussion in 'The Garage' started by TwistedSkipper, Jul 27, 2006.
  1. TwistedSkipper
    TwistedSkipper Registered Member
    May 23, 2006
    18
    chicago
    OK, so I have these POS 31x10.50x15 that were on my truck when i bought it. I want to put some 33" mtrs, but I am a afraid that on my 15x8 rims, that I will need more than the 3 inches i have before i hit the top of the garage door deeming my workplace useless. Obviously, from a 31 to a 33 should be no problem, but the 8 inch rims will make the tire stand taller right? I dont want to find out after i have them installed if you know what i mean, Help please.
  2. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    You prolly have 15x7 or 15x8 rims already on there. And youll only gain 1" of lift if that by going to 33's i beleive. I am going to say youll fit. I sure wish i still fit in a garage.
  3. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Just air down if you don't fit.
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    When you hear the crunch, stop -
  5. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    hmmm, never thought of that, guess it would be worth it if you needed to do some kind of work that would be best off done in a garage
  6. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    my burb with 2 1/2" lift and 32/11.50/R15's fit in mine just barely
  7. dyeager535
    26,979
    My truck on 33's has cleared 3 different garages fine, but it's not lifted. And of course the catch that all trucks are slightly different. :)
    Rim width isn't going to have much effect on tire height, (in your situation) and as mentioned, you can always air down if necessary.
  8. goldwing2000
    goldwing2000 Guest
    That was my first inclination, too.
  9. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    A buddy of mine can fit his K30-frame scout on 40's in his standard 2-car garage by letting all the air out of his tires.
  10. gtchief
    gtchief Registered Member
    Apr 15, 2004
    33
    I have 32x11.50 on the stock alloys with a 1" body lift and I make it in my an inch.
    On another note, how will 33x12.50 work on the stock 15x7s? I know normally you should have atleast a 15x8. Thanks
  11. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    as are all garages and driveways.
    FWIW, mine fit in on 31s, with 6" lift, no motor/trans/case, and no front clip (all making it taller, due to no suspension compression)
  12. goldwing2000
    goldwing2000 Guest
    Oh, I'm sure you'll get them on there but it will look like a ring bologna around the wheel.
    Unless you're rock crawling or doing something else where you have a serious chance of the bead coming off, you should try to keep your wheel width within a couple inches of your tire width. Otherwise, you'll burn up the center of the tread long before the edges.
    Well... unless you have money to burn on tires all the time.
  13. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    ratchet straps can around the springs/frame can grab you a few inches. I've found a garage my truck couldn't fit in stock so be careful.
  14. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I have 4 inches and 37s and mine fit in the garage. I put a zero rate in the rear and had to have readymix drive it out while I stood on the rear bumper to squeeze out of the garage. She no longer fits:( .
    Ira
  15. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    must be nice to fit in a garage. my garage is so short i would hit my windshield
