will it fit in the garage???
Discussion in 'The Garage' started by MITCH_89', Apr 29, 2004.
  1. MITCH_89'
    MITCH_89' Registered Member
    Dec 7, 2000
    91
    GULF BREEZE, FL.
    I bought a new house, and finally have a garage. My Blazer has 4" tuff country lift, and 33s. I have the top off, and I clear my garage by 3.5". Can I fit 35" tires and still get in the garage. I dont know anyone that has some I can try before I make a mistake and buy them??? Thanks
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Suuurrrre it'll fit,,,
    little bit of this to the garage opening,,
    /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif
    Little bit of this to the truuuuuck,,,
    /forums/images/graemlins/grind.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/grind.gif
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    The 35's will actually only give you 1" of lift over the 33's. You should be OK
  4. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Technically apeaking it should fit.
    You should only get 1 of the 2" below the axle therefore only lifting the truck 1".
    How big is your garage, my 2.5" lift and 33's and the roof rubs the door.
    Still in GB?
  5. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Mine has a 4" Tuff Country lift with 38's and no top, it BARELY fits /forums/images/graemlins/thumb.gif
  6. MITCH_89'
    Dec 7, 2000
    91
    GULF BREEZE, FL.
    I think Ill go for it...worst case, my air compressor will get a daily workout /forums/images/graemlins/wink.gif
  7. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    Go for it /forums/images/graemlins/waytogo.gif
  8. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    It will be close...if it won't fit then back up 100 yards, floor it, and right in. Getting out willbe a different story. /forums/images/graemlins/doah.gif/forums/images/graemlins/rotfl.gif
  9. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    Measure to see if where the door stops going up because mine stops about 2" below the opening. Or just air down and pucker up. /forums/images/graemlins/shocked.gif
  10. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,072
    483
    Grand Rapids area
    I think 7' is the standard height garage door. I know mine is and some other houses I looked at before I bought this one all measured in right at 7' 0". My truck is 6'10" high with 35's and about 5" of suspension lift. You have to pay attention to the slope of your driveway and garage floor, because the truck will pitch a little bit, eating up some clearance. Without a top, this is easier.
    Most garage door openers can be adjusted for the open position. Make sure the door is not eating up clearance. I also moved a 1" weatherstrip off of the opening and mounted it on the door itself for 1" additional clearance. If it's close, take a look at things and see what you can move. /forums/images/graemlins/hack.gif
  11. limey
    limey 1/2 ton status
    Dec 17, 2002
    121
    midland texal
    if its to big you will just have to air down the tires ..... but blazers are out door creatures
  12. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    I laughed pretty hard when read your post cut hereand grind there /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  13. unclematty
    Jan 24, 2003
    3,164
    SLC UT
    I'm envious of any one who can get their truck in their garage. mine's way to high. I'd have to take the wheels off to get it in, and thats with only 36 inchers on it. /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
