Will it fit?
Discussion in 'The Garage' started by 82_k5, Feb 8, 2004.
  1. 82_k5
    82_k5 Registered Member
    Oct 3, 2003
    94
    I own an '82 Jimmy with a very tired 305, i have found a '69 Chevy station wagon with a 350 with 50,000 miles on it. My question is will it be a bolt in deal or will i have to fabricate a bunch of stuff? The emissions doesn't matter because the current motor has already been stripped by the PO. thanks /forums/images/graemlins/1zhelp.gif
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    it will fit. u will have to use the engine mounts from the K5 & i would use the assc. from the K5. it is all bolt on.
    P.S. delete one of the posts u posted it twice.
  3. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    should fit in easy the only thing you should have to mess with is the motor mounts
  4. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    It should be an easy swap.The only diff. is poss. the waterpump,alt or pulleys.Use the ones on the 305 and you shouldn't have any suprizes.If the 69 has points instead of electronic dist.,just use your 305 dist. /forums/images/graemlins/waytogo.gif
