Will Late Model 16" 8 lug take offs fit '81?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by paniolo, Dec 10, 2002.
  1. paniolo
    paniolo Newbie
    Dec 10, 2002
    Will Late Model 16\" 8 lug take offs fit \'81?
    Hi all, I searched for this but didn't find any answers. I just bought a '81 2500 Sub and the 16.5" tires need replacing. Noticing all the 16" 8 lug alloy takeoffs that are available I was hoping I could pick those up for basically the price of new tires. I have gotten conflicting opinions on if those will fit.
    My burb is in real nice shape, no rust, new paint, '93 454 converted to carb with about 70k on it so I am debating keeping the classic look, but the PO did put a cowl induction hood on it and I think the new alloys would look pretty sharp.
  2. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Re: Will Late Model 16\" 8 lug take offs fit \'81?
    Yes they will if you are talking about Chevy or GMC takeoffs. They are the same bolt pattern as your 81. Ford changed theirs in 99 to 8x170mm and these will not work on GM or Dodges cuz they both have the 8x6.5 bolt circle /forums/images/graemlins/grin.gif
    Hope that helps /forums/images/graemlins/thumb.gif
    Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I think they're gonna fit. I know there's offset issues with the 6-lug wheels, but the 8-lug wheels should be okay. If I'm wrong, somebody will let me know /forums/images/graemlins/grin.gif
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    They might rub the tie rod ends, thats the only issue i can think of
  5. dyeager535
    26,980
    2wd or 4wd?
    IFS wheels fit, but the "centercaps" can't be made to work as is with the solid axle hubs. Dad put a pair of late model 16" wheels on his '74 K20, and ended up with no centercaps. If you are talking 2wd, can't imagine there would be any problem.
  6. paniolo
    paniolo Newbie
    Dec 10, 2002
    Yeah, I'm talking the 12 hole Chevy/GMC takeoffs... I knew the bolt pattern would fit (with the exception of the 99+ Fords all 8 bolts are the same pattern) what I was concerned with was the backspacing and any suspension or body interferance. It is for a 2wd also. Thanks for the input...maybe I can find someplace local to test fit them first.
  7. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
  8. dyeager535
    26,980
    The ones he's got are plastic with a Chev emblem on them, and they'd look just like yours when he was done, hub sticking out of what used to be the centercap /forums/images/graemlins/smile.gif
  9. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    Mine were the chevy style also. Be very careful when cutting the center out, they break easy. I used a lathe and a parting tool, turning VERY slow.
  10. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    They did on my 91 sub, with 80 3/4 ton axles under it! BUT, they socked me for a set of lug-nuts to match! (good thing it had the 'show-nuts' & centers too!
