Will MIG welders do the job?
Discussion in 'The Garage' started by 84gmcjimmy, Feb 15, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I have a Millermatic 175 MIG welder (im from Canada) and I was wondering if it would hold up to welding roll cages, bumpers, rocker panel protection, etc. I have had it for a while but haven't used it. The placed messed up and gave me .030" tips, and .035" wire.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    just get some .035 tips, no big deal. I used a 135 Lincoln for all my fabwork. Truthfully I wish we hadn't gotten rid of the 200 we had, oh well that wasn't my descision. So I'd say it should be fine, is its a gas or just flux core? I doubt its just flux core. Don't go doing roll cages and important stuff like that if you've never used the welder though. Practice a lot, I've been welding for years now and I'm just getting the hang of doing it right. I'm also just starting to weld a lot.
  3. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay, yeah I was just saying for future projects. I need to practice. Ive welded before, but just on a friends machine.
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    .030 wire is actually better for rollcages. The average cage tuning is made of .120 wall and the .030 is best. 1/4" plate works well with .035 wire.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I built my entire truggy and stuff for other peoples rigs with my MM 175. IMO, it's the perfect size welder (price/value) for a home shop and 4x4 hobbyist.
  6. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Should work well. Just make sure and notch (groove) all the joints to get good penitration, and you should have no problems.
    John
  7. CammoK5
    CammoK5 Registered Member
    Apr 8, 2003
    73
    Texas
    I've built a lot of stuff with my little Craftsman Mig welder. I was suprised at how well it welds for a "cheep" machine. Like the others, I think it would be fine for what your doing.
    /forums/images/graemlins/crewcab.gif /forums/images/graemlins/usaflag.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A MIG will do nearly anything a stick welder will do, just cleaner and better.
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    and more expensive, to = the strength of a good stick weld you need a strong Mig welder that just means more money for a better welder. Like I said, shouldn't have gotten rid of our 200.
  10. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    You like it? I heard thats a pretty nice one, I was thinkin about gettin it.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes, more expensive. A 225 amp stick welder costs $229. A 210 amp MIG will run you $1k+. The MIG will do almost anything the stick will do though--and it will do it cleaner and easier.
    I never intended to talk down stick welders at all, but years ago when I first started welding I was under the impression that a MIG wasn't capable of doing what a stick welder can using thick stuff. The first time I saw a 200 amp MIG in action, I was sold on the idea.
    Ideally you'd have both, but if I had my choice of a 135 amp MIG and 225 AC stick welder OR just one 175 amp MIG, I'd have the MIG. It's just so much easier/cleaner plus you can do body work with it. Only downfall really is the 220 v outlet that is required for the 175.
  12. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I prefer my gas motor powered miller 400 amp stick welder because it has more power than both migs we have and can burn right through some thick stuff. I do a lot of hardfacing(hince why I have so much heat) and it is a lot easier with a stick welder. As a matter of fact I don't think you can even get hardface wire. /forums/images/graemlins/thinking.gif The migs do a cleaner job with less splatter though.
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I totally agree if I had the same choice I would go with the 175. And for the one who asked if I like the 135, its really nice, easy to move(little and 120V) and does a good job but I sometimes feel I could use just a little more heat.
  14. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    [quote And for the one who asked if I like the 135, its really nice, easy to move(little and 120V) and does a good job but I sometimes feel I could use just a little more heat.
    That was me. Yeah thats what I was curious about, was the heat. Thanks!
  15. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I wouldn't give the 135 up for anything, but the 100 I have I'd gladly trade for a 175 /forums/images/graemlins/smile.gif
  16. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I'm glad you wrote nearly in there. There is 1 reason I keep a stick welder. If a part on a piece of equipment breaks that has to be fixed yesterday and is hard to get to it gets the stick welder. A mig is wonderful until you try to weld used metal. Then you have to clean the weld area which in some cases it's just not possible to clean it sufficient for a mig without disassembling the machine. A stick welder will blast through rust, oil/grease, paint, whatever. I have used the stick many times like this on our backhoe when it would break and we had a grave to dig and no time to tear stuff apart.
    That being said when I can use it I do love my mig /forums/images/graemlins/thumb.gif
  17. jedifish
    jedifish Registered Member
    Feb 14, 2004
    12
    Miller's r probably the best Mig machines out. There r others that r good as well. I have a Hobart Handler 135, which is made by Miller. I couldnt afford the Miller 175, I had very limited funds at the time, but I love it. I had a friend with a cheap Chicago Electric, he used it for a couple of years. He builds hot rods and when he started out he had the Chicago Eletric and it worked for him until he got more work and had to get a bigger machine. And he got a Miller. They r just super nice machines. And by the way The Chicago Electric is still working. You have a really good machine and it will work for your needs.
