Will my 14BFF bolt up to where my 14BSF is?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Aug 7, 2002.
    Are the U-joints the same? Will it just bolt in? Thanks
  1. Quack_Addict
    Quack_Addict 1/2 ton status
    Feb 24, 2002
    119
    Michigan
    The 14FF will bolt right in to replace the 14SF... I don't know if the U-joints are the same though. Drive shaft trimming may be needed - I think the pinion yoke sticks farther out on a 14 FF.
  2. I mean I know it will bolt right in place but I was just curious about u-joints. Thanks
  3. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    I'm pretty sure they both use the same 1350 ujoint. My 14sf does.
  4. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    The pinion on the FF is SHORTER than the pinion on the SF. U-joints are the same. I swapped out a SF for a FF in a '88 3/4 ton suburban.
