will my 6.2 be happy with 3.73 gears??
Discussion in '1982-Present GM Diesel' started by 84CUCV, Apr 21, 2007.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    it a 6.2 th400. Still not to sure how to figure out the rpms. thanks for the help
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well it depends what size tires you will run but with the th400 you can go taller gears so 3.73 should get your RPM's lower for better MPG.
    That is assuming you had 4.56 beore since you have a M1008 CUCV right?
    Or did you have a M1009 with 3.08?
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    i have both cucvs. i am taking the axles from a m1010 and taking the 3.73 3/4 ton and putting them into the M1010 and going to sell it i hope. will the 6.2 be able to hit 70mph ok? thanks
  4. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Assuming 31" tires it'll be doing about 2850 rpm at 70 mph. Not great, but doable. 2650 rpm if on 33's...
    Rene
  5. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    I have some 33s. thanks a lot
  6. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    No problem.
    Speed x gear ratio x 336 divided by tire diameter will get you very close.
    Rene
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    thanks rene
  8. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    There's one calculator: http://www.phnet.fi/public/mika.jussilainen/laskuri2.htm
    I was woried that I'm killing the engine with 4 speed box (I may have found SM465 dirt cheap) with 33" tires and 4.56's, but after some calculating rpm's are around 2320 when going 50 mph (that's as fast as I can go legally with 'Burban). Someday I get NV4500, but at least for now they are really rare in here.
  9. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
  10. CumminsChick
    CumminsChick 1/2 ton status
    Jan 19, 2007
    127
    Lexington KY
    mine will hit 70 but i have 456s, came stock with 3.73 (no lift) and she'd hit 70 on a good day.
  11. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    ok thanks
