will my 91 FS blazr rims fit on my dads 2001 silverado?
Discussion in '1992-Present Chevy & GMC models' started by FatBoyBlazer, May 5, 2002.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    they are the factory aluminum rims with worn out 32 inch emingto mud brutes on them...will they fit?
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    both 6 lug? if so then yes.
  3. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    what about the tires....isn't the back spacing and having the 2001 having disc's all around make a problem
  4. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    no - i believe the '99up trucks are hub centric, as opposed to the earlier models trucks that are lug centric
  5. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    NNNNNNNOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!
    they wont fit....they will go on- but they will hit the caliper's..we tried to put some rims on our 99 that were on our 94 and they did NOT fit...they actually ended up putting some stress cracks in them, and the rims are now basically junk...
    DONT DO IT!
    Brandy
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    heres an idea...try one. place it on there and see if you can spin it with no weight on the tire, as in by hand in the air not driving it.
    You never know til you try it, there are too many varibles..backspacing, rim width, tire width.....
    i know a 2001 rim will fit on a 1990 truck and a 1996 suburban..my friends uncle has stock 2001 silverado rims on both.
  7. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The backspacing is different. 3 1/2" for the old body style, and 5 1/2" for the new stuff. They will bolt on (if the wheels clear the brakes), but the tires will stick out of the wheel wells.
