Will my 98 z71 pickup rub with 285/75/16s? (33.1x11.3)
Discussion in 'The Garage' started by AFUFO, Mar 1, 2007.
  1. AFUFO
    AFUFO 1/2 ton status
    Apr 26, 2006
    329
    Chesapeake,Virginia
    We have a 98 K1500 Pickup with the Z71 package. The truck came stock with 265/75/16. We want something a little wider and taller, that sticks out a little more..make the truck look more like a truck.
    Will 285/75/16 (33.1x11.3 overall size for trailcutter mud terrain) rub for street use? A bit of mud, very little trails with rocks..(going in april, that will be the only trip to trails like that).. Will be on sand a bit too but that dosent need flex.
    Lifts are out of the question for this daily driver, and we dont want to fendertrim unless its very minor and hardly noticable.
    The Trailcutter M/T specs are here-
    http://www.laramietire.com/line/specs/tlt_trailcutter_radial_mt.htm
    Vid of our truck.. front sits a tiny bit higher now too, Had torsion bars cranked up a tiny bit(was crooked), and add a leafs are being installed in the rear soon.
    www.crookedhousecreations.com/SIMG0071.AVI
    pics are under the "how will my truck look with xxx lift and xxx tires" thread, 2 pages from the end. Right now we have 275/70/16 Dueler A/T revos..kinda bald now
  2. AFUFO
    Apr 26, 2006
    329
    Chesapeake,Virginia
    This can be moved to the proper forum, but i wont be able to respond except via edit (will i be able to edit still?).
  3. AFUFO
    Apr 26, 2006
    329
    Chesapeake,Virginia
    buy one bump get another bump free! Bumped from page 8
  4. Casey97z71
    Casey97z71 Registered Member
    Oct 1, 2006
    19
    San Luis Obispo, CA
    They'll fit, I ran 305s on my 97 with no rubbing.
  5. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,853
    280
    Truckee, CA
    Ok stock wheels they will be ok. Maybe a LITTLE torsion bar crank and trimming, but on aftermarket wheels they will rub.
  6. AFUFO
    Apr 26, 2006
    329
    Chesapeake,Virginia
    Stock z71 wheels =) Wish they made aftermarket wheels that looked like the z71s, then i could have them on my Jimmy.
    I asked because i saw my friends 94 fullsize blazer, and his 265s look like they almost rub, which is why i got worried 285s wouldnt fit. i think he has aftermarket wheels, and his truck might have had smaller stock tires i dont know.. i know its not a z71.
    This is his truck-
    Lol..that top is begging to be sawed off.. trying to get him to do it to the one hes about to get for a trailrig.. either cut it off forever or make a track system for it.
  7. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    you should be fine.. my mom runs the same exact size on the stock wheels on her 96 yukon and ive never experienced any rubbing when i drove it
  8. Cajun4x4
    Cajun4x4 1/2 ton status
    Oct 17, 2005
    889
    Lafayette, LA
    not one bit
  9. AFUFO
    Apr 26, 2006
    329
    Chesapeake,Virginia
    Ok sweet thanks guys
  10. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    My friend had 285's on his '96 Z71 before he SAS'ed it. He had the torsion bars cranked a bit and an add-a-leaf in the rear. The only rubbing was on the lower control arm when he turned the tires all the way to one side or the other.
    He did manage to get the front left tire to rub the upper lip of the fender when landing from a fairly good size jump, but that was the only time.
