Will my Axels survive?
Discussion in 'The Garage' started by drop the hammer, Dec 8, 2006.
  1. drop the hammer
    drop the hammer 1/2 ton status
    Feb 26, 2006
    160
    Massachusets
    Alright heres the skinny, I currently own a '83 K-5 350, 700-R4 with 6inch lift and 35in Mudders. I am planning on Hacking the fenders and stuffing 38's in when the mudders wear out. I currently have a 12 bolt rear and Dana 44 front. Both axels are unfortunatly open but I plan on giving them both the detroit treatment in the future, maybe a spool in the back, and Gearing them dowm from the garbage 3.08 to 4.11's or 4.56's. Will they survive? Or do any companys make the stuff I need to beef them up to it. I'f had success beating the crap out of 12's and 44's in the past on 36's so I dont think 2 inches makes that much differnce. Also wandering if any one in the Cape Cod area is sitting on a 465 cause I hate my auto and gotta get back to a stick
  2. rwright07
    rwright07 1/2 ton status
    Jul 30, 2005
    536
    corporate hobo
    thats alot of tire and gear for a 12 and 44...even w/out lockers . Id go w. at least 3/4 ton stuff
    u can get a 14ff for liek 200 bucks.. the 3/4 ton will bolt right up, then get 3/4 outers for the front-if not jsut the whole 3/4 front axle to get matching gears... that would be cheaper than regearing your front end. a 3/4 ton front will bolt up too
  3. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Well hello fellow Mass-hole! :D
    I would suggest upgrading your axels to a 3/4ton set. They have all the strength you would need and already have the lower gears in them.
    I plan on upgrading to a 14bsf rear end soon so i don't have to get 8 lug wheels over the existing 6 lugs now.
    As for the SM465, a friend of mine has a 2wd version with a hydro clutch, but you will have to swap the output shafts inorder to run a t-case behind it.
    Since you are in the area, look for The Want Advertiser in convenience stores and such. They have a huge Chevy trucks section and a huge truck parts section. Its the perfect place to find yourself a set of 3/4 ton axels and a 465.
  4. 85-m1028
    85-m1028 1/2 ton status
    Apr 26, 2005
    485
    costa mesa california
    What's an axel? :dunno:
    I just figured out what stiring weel is!!:haha:
  5. destinbeachman
    destinbeachman 1/2 ton status
    Aug 31, 2005
    365
    Florida
    No,they will not survive.Your axles,that is.Not your axels.:D
  6. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    X2..It's just a matter of time and or "Drop the Hammer"
  7. drop the hammer
    Feb 26, 2006
    160
    Massachusets
    Looks Like I gotta keep up on the Want ad and craigs list for a wasted 3/4 ton parts truck or the axels on there own. Anyway I know drop the hammer is a queer name to use but I though it was cool when I was 14 and made my first forum name and have just kinda stuck with it. "When in dought drop the hammer on the gas, it might not make your situation any better, but it make it over sooner"
  8. TeK
    TeK 1/2 ton status
    Jan 3, 2005
    170
    Greenwood, IN
    I've got a 1 ton Dana 60 rear for sale with 4.88s and a Detroit. You could pair that with a D44 or D60 front and have a nice set of axles.
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    *doubt*
  10. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    If you keep the Dana 44 open it will live just fine with 38s if you lock it be gentle. The 14b ff or sf just gives a whole lot of peace of mind. Remember if you find a set of 3/4 tons they are more than likely going to be 4.10s if you are lucky they could be 4.56s if you are unlucky they could be 3.73s probably will be the 4.10s
  11. drop the hammer
    Feb 26, 2006
    160
    Massachusets
    with the 465 conversion 4.10 gearing should be plenty deep for 38's right? I'm not a crawler more of a mudder and my first truck pushed 36's with 3.90's and a T-18 backed 302
  12. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    you can spend a lot of money to upgrade the front axle or you can spend that same amount of money of a stock 60 and "drop the hammer" any time you want and know it will take it.
    I did it the hard way and wasted tons of money on a dana 44. Warn HD shafts, HD u-joints, hub fuses, locker, rebuild. I replaced everything except the housing, knuckles, spindles, and hubs.:doah:
  13. drop the hammer
    Feb 26, 2006
    160
    Massachusets
    screw it I'll just have to save up a lot more and cut the hell out of the fenders and shove 39in tsl's on my K-5 so I know my axels will die and when they do my wife will be forced to let me upgrade to 1 tons:wink1:
  14. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    well dont wast ur money into the 1/2tons now....just keep it the way it is and then upgrade when u get the money.
  15. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    A SM 465 does not have an "output shaft" in the way you are describing. What you're seeing sticking out from the back of the tranny is the end of the mainshaft which means to 'swap it out' you'll need to completely dis-assemble and install a new mainshaft with the correct output splines, plus add the correct T-case adaptor. All that work for a $50-$75 tranny really isn't worth it IMO when you can find 465/205 combo's all day long for about $300.
    As for 1/2 ton stuff surviving with 38" or 39" tires...sure, as long as you don't wheel it. Then again, good luck stopping with the puny 1/2 ton brakes. Also, those wonderfully strong 7/16" lugs (all 6 of em) should inspire confidence too. :rolleyes:
    I know I'm repeating what others have already said, but there are more reasons that axle strength to consider when going with larger tires. If you're looking for tires in the ~39-40" size I would recomend 4.56's at least...even with the SM 465 and only mud in mind. For trails and rocks 5.13's or 5.38's would be better. 4.10's will be clutch killers.
    Rene
  16. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    sorry I meant main shaft... :doah:
  17. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    It sure would be nice if they were designed with removable/swappable output shafts wouldn't it?
    Rene
