will my brake lines swap to a 60?
Discussion in 'The Garage' started by supersize75, Dec 20, 2003.
  1. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    I am hearing yes and no from many people that my brake lines "aftermarket" wont work when I go from my dana 44 to my 60.
    this has me all confused now /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Nope, the D60 is the same as a 10 bolt.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    If you have D44 calipers they will not fit, if you are using 10 bolt calipers they will fit. The banjo bolt sixe is the difference. Also when I swapped for a D60 I had to modify my 10 bolt hoses because the banjo block itself was too big to sit flat and seal properly.
  4. supersize75
    Sep 27, 2002
    2,638
    ah thanks guys /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    So what and how did you modify it?
  6. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Ah ha, I didn't think about the fact you are running a d44. Sorry
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You doubt me... /forums/images/graemlins/smirk.gif
  8. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    MY extended lines for my 10 blot bolt right on to my 3/4ton d44 was that only because i had the bolt for the 44 caliper or somthing? /forums/images/graemlins/thinking.gif
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just go get yourself some 88 C1500 hoses. /forums/images/graemlins/smile.gif
  10. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    when i went 10 bolt to d60 with procomp stainless lines, I had to use the grinder just a lil tiny bit on the corners of the block to get it to fit, no big deal.
    j
  11. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    When I swapped my 10 to a d60, I had to buy new lines. No joke, the 10's wouldn't fit no matter what I did. The 10blt lines were about an 1/8- 3/16" off center. I swear I'm not crazy... even left a fist size dent in the quarter panel, from fustration. And yes it was a 10bolt not a 44. I'm the only person I know that has had that problem.
  12. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    weirdness... were they factory lines or some kinda aftermarket ones?
    j
