Will my computer run a Vortec?
Discussion in 'The Garage' started by tiger9297, Mar 15, 2005.
  1. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I have found a Vortec engine out of a wrecked truck. I have a '90 K5. I was wondering if my computer, with a reprogrammed chip, would run a vortec engine?
  2. dark eternal
    dark eternal Registered Member
    Jan 15, 2004
    22
    Dallas, Tx
    99% sure you will need an entire new computer from that model year engine vehicle.
  3. dyeager535
    26,979
    Vortec requires/uses a PCM, and it is CPI not TBI, as well as OBD1 vs. 2 which changes a BUNCH of things in relation to the computer.
    Heck, for all I know with a TON of work on your part you *might* be able to make an older ECM work, but I guarantee, IF it's even possible, it's not a simple PROM modification. Not going to be worth the time or effort, especially when folks on here have installed Vortec motors in their trucks without trying to utilize older components.
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I agree. The TBI based ECM most likely does not have nearly the capacity or the provision for all of the sensors required to run a newer Vortec motor. Another option would be to re-use the TBI setup by buying a new intake manifold.
  5. tiger9297
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    Well I would like to get 400+ hp. (I know I would have to modify a Vortec engine to get that). I have looked at just building an engine with Vortec heads or some other aftermarket heads, cam, pistons, and this induction system- http://www.firstinjections.com/ Is anyone running one of these?
  6. dyeager535
    26,979
    Yeah, but if thats the case, just swap the heads onto your block. TBI intake is a cost prohibitive piece.
    Nothing real special about the Vortec short block (besides roller cam) so if you aren't installing it as is, I wouldn't bother doing the swap at all. Just personal opinion, but part of the "beauty" of the Vortecs is the CPI, you remove that, you remove most of the benefit of the swap.
    My opinion of course.
  7. tnscrambler
    tnscrambler Newbie
    Nov 8, 2003
    3
    I've got a '99 model vortec 350 in my '86, It uses a custom harness from howell to use the stock vortec computer, has all four O2 sensors, data link conector for obdII, etc...
    Its nice, but the harness cost $700:(
    Good luck,
    Justin
  8. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    I wouldn't pay 2 grand for that injection setup...the vortec manifold doesn't appear to be ready yet either. I think you could get a similar setup for about half that price (SDPC vortec base ~350, used LTR's, ported plenum, used 52mm TB, and the rest stock tpi stuff, maybe injectors and a prom(~150 or burn your own)
    but it would pry be better just to leave the vortec block alone and run it like the others said
  9. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    You can buy a Vortec to TBI adaptor intake for I believe $200.......it's a performance style intake so if you are getting rid of the stock intake anyway it's not that much more money. A guy here at work just swapped in a GM Vortec crate motor into his '95 that had TBI using this method and it runs really good.......granted the crate motor is rated at 300 hp. But he has all of the stock sensors, ECM, etc. Even using a stock Vortec motor converted over to TBI should gain a noticable power increase and a little more room for modifications. However, if your goal is 400 horses you may need to start someplace else because any of the stock EFI setups might have trouble supporting that level.
  10. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    Technically, yes it can but it wouldn't be easy and why would want you? Most of GM's sensors really haven't changed from the TBI/TPI/MPFI systems. There are just more of them. The computers just got smarter and engines got better.
    If you want to keep it fuel injected just get the computer and harness with the engine and use it. Otherwise, swap it over to carbed, or the TBI adapter. There are a few of use that have done the swap and are around for help. I used a 5.7 out of a 99 tahoe, with a 96 computer and the stock wiring harness. I can go into details of why/how I did this if your interested.
    Mike
