Will my driveshaft work?
Discussion in 'The Garage' started by BlitzK5, Jul 30, 2005.
  1. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    I just installed my new 14 bolt FF with a 4" shackle flip and new OEM springs. I am going to be installing a 1350/1310 u joint so I can connect up to the stock 1/2ton driveshaft. I am running a NP 208 with 4 degrees at the rear yoke. The 14bolt has 14 degress at the pinion and the driveshaft is at a 24 degrees. Will I experince any driveshaft binding with these angles? or will is survive? I dont want to waste any money on a new driveshaft because I might be swithing to a 205.
    454/TH350/NP208/4" lift/10 bolt F/14 bolt FF/38X15.5X16.5
  2. BlitzK5
    Jul 29, 2005
    288
    Anybody?
  3. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    switch to the 205 first.
  4. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    I just went through this, except my angles weren't as severe as yours. I had a very bad vibration due to this and it would get the u-joints so hot that it would liquify the grease in them and would sling it all under the truck. I had to grease them weekly. It also wore out the bushing in the t/c tailshaft housing. I drove it this way for about a month, then I ordered a cv shaft from Jess at H.A.D. and it solved all of my problems. Even with that you're probably going to have to do some angle correcting.
