Will my K5 Bend During Body Work?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kim tate, Dec 17, 2001.
  1. kim tate
    kim tate 1/2 ton status
    134
    New Orleans
    I've removed the doors and inner wheel wells (front). I plan to remove inner and outer rocker panels next. Are these body parts considered structural? Will the truck bend while I wait for the next free weekend to replace with new panels? I plan to reinstall in reverse order. First rockers, then wheel wells, and eventaully the doors. I'm in need of your advice. Certainly don't want to fight to get truck back in alignment as I attempt my first body work. Thanks.
  2. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    No, your truck will not "bend" The frame is designed to support the body.
    " Wider IS Better!!!"<a target="_blank" href=http://www.community.webshots.com/user/wheelininco>www.community.webshots.com/user/wheelininco</a>
  3. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    You're laughing [​IMG][​IMG] if you're body is still mounted up to the frame! I had the entire rear floor out &amp; half the front floor when I cut the rockers out from the door sill down &amp; that was with the empty body perched on stands; completely empty with no doors; frame; anything!!!
    You'd be amazed how strong steel is; even a small strip like sheetmetal! No; it's not going to hold driving or anything but for keeping itself together just sitting there; it's perfectly fine!
    Good Luck
    Brian
    89KBlazer
    Build it Right or Don't build it at all!!
  4. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    As long as your mounts are good, and not rusted through, and it's not a full convertible then your fine.
    Like em big and topless
    Excuse me...Would you mind removing your import from under my chevy?
  5. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I would tack weld in a brace or 2 before cutting out the rocker panels. Granted what I did to mine was more extreme than what you are doing, but I had a few braces in mine and still had to do some work to get everything in place before I welded the new pieces in.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
