Will my SM465 bolt up to a 1990 Corvette L-98 engine?
Discussion in 'The Garage' started by 72Blazerod, Jul 1, 2002.
  1. 72Blazerod
    72Blazerod 1/2 ton status
    May 18, 2000
    264
    Vancouver, British Columbia, Canada
    Hi guys,
    I am off for the summer and finally have time to work on putting that 1990 Corvette engine into my 1972 Blazer. I got to thinking, is my SM 465 going to bolt right up to this Corvette block? If not, what do I have to do to get this sweet TPI power plant hooked up to the rest of my drive train?
    Thanks for your help,
    Rod <font color="blue"> </font color>
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    As long as you have the proper flywheel for that generation of motor the rest should bolt right up. The bolt pattern for the bell is the same as all other small blocks.
    You will need a flywheel that is compatible with the one piece rear main seal design the 90 Vette motor has though.
    Rene
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The only gotcha that I can think of is that the 'vette engine may not have a boss and hole for the ball that supports the clutch linkage. I can't remember when they stopped those. But if you're using a hydraulic clutch linkage, then that won't be a problem. /forums/images/icons/cool.gif
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    isnt the bell the location of that pivot in a truck?
    go hydro and never look back
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The only pivot on my Jimmy is off the bellhousing...
    Rene
  6. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    Do you think you will have a problem with your dist with firewall clearance?
    /forums/images/icons/confused.gif I would ask that ? on the gen 1 board good luck with your project /forums/images/icons/grin.gif
