will my TH350 bolt up to a newer 350 block?
Discussion in 'The Garage' started by barneybasher1010, Jan 27, 2007.
  1. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    will my 79 th350 bolt up to a 1988 350?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, but you'll need to use a flexplate that's made to fit the '88. The bolt pattern on the crank changed when they went to the 1-piece rear main seal. There are 2 different diameters for the torque converter bolts, so you'll need to check that. Most aftermarket flex plates have both patterns drilled so they'll work with pretty much any GM torque converter.
  3. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    X2 for
  4. barneybasher1010
    Sep 25, 2005
    908
    PORTERVILLE CA
